kyb shocks squeak -SOLVED
Old Feb 4, 2019 | 06:08 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
I installed kyb agx shocks a few weeks ago. after a few days they started squeaking. I tightened the upper mount and they stopped squeaking for about 15 miles. I then sprayed the rubber with wd40 and it helped. I continued to spray them each day until they stopped all together. that lasted a few days and now its starting again. I don't recall the installation instructions saying anything about greasing the rubber bushings but that's all I can think to stop it. anyone have experience with this?
Old Mar 5, 2019 | 12:04 PM
hotrodf1's Avatar
Car: 91 Z28
Engine: 350ci "fastburn 385"
Transmission: T56 / Quartermaster clutch
Axle/Gears: 9", 4.11, Auburn Posi
Re: kyb shocks squeak
Hey, I have this same issue with my rear AGX units. Drives me nuts. I haven't spent a whole lot of time diagnosing anything. I got under the car and wiggled the shocks around some one time, and the squeaking stopped for a while. But it's back again.
Did you fix yours yet? What did you end up doing?
Old Mar 5, 2019 | 12:17 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Always grease rubber/poly bushings with the correct grease. The other issue could be tightening the hardware, you should do this at ride height so that its natural "center" is at the ride height.
Be careful with WD-40 it actually cleans grease off and will make the issue worse and worse over time.
Old Mar 6, 2019 | 06:37 PM
Evilokc's Avatar
Engine: tbi 305
I sprayed them real good with wd-40 from the top and they stopped squeaking for a few days. im going to drop them and put some bearing grease on the rubber. I will never buy another set of kyb shocks. ive never had a set of shocks squeak like this. drives me nuts and makes the car seem like a piece of crap because its so noisy.
Old Mar 6, 2019 | 06:38 PM
Evilokc's Avatar
Engine: tbi 305
what is the correct grease. the kyb directions didn't tell me to grease them so I didn't think about it.
Old Mar 6, 2019 | 06:44 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Silicone based synthetic water-proof grease
This is what I usually use, don't use axle grease.
https://www.amazon.com/gp/aw/d/B0042FG74W/ref=ox_sc_act_image_1?smid=ATVPDKIKX0DER&psc=1
Old Mar 6, 2019 | 09:17 PM
Evilokc's Avatar
Engine: tbi 305
https://www.amazon.com/gp/aw/d/B0042...KIKX0DER&psc=1
thanks I will give it a try.
Old Apr 20, 2019 | 09:37 PM
Evilokc's Avatar
Engine: tbi 305
Re: kyb shocks squeak -SOLVED
greased them well with the silicone based grease and they stopped squeaking immediately. thank you for the help guys. it was driving me crazy.
92RSSlowmaro
Feb 22, 2005 09:26 AM
91NiteRida'
Dec 12, 2004 02:31 PM
squirrelybird
Sep 8, 2002 12:30 PM
primer84z
Apr 3, 2002 11:27 PM
BowtieFever
Nov 17, 2001 10:50 PM
