Can't get rear to sit even.
Old Oct 2, 2022 | 06:46 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
Installed a new rear end and now I cAnt get the rear even. it's an inch off. I'm assuming it's the spring clocking but I've moved the low side around to get it to match the higher side and I'm not having any luck. Words of wisdom? The driver side is so low I. CAnt drive it.
Old Oct 2, 2022 | 07:08 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Re: Can't get rear to sit even.
I believe bottom of spring coil ends towards outside of car
Old Oct 2, 2022 | 07:15 PM
Engine: 5.7 l98
are you sure you didn't forget the ring that goes above spring on one side? I usually put a piece of scotch tape on the top to hold it in position when installing. I think the clocking needs to be correct and can't be spun around
Old Oct 2, 2022 | 08:39 PM
Evilokc's Avatar
Engine: tbi 305
i have the taped on the top of the spring
Old Oct 2, 2022 | 09:31 PM
Measure THE CAR, not the trim (fender).
Old Oct 2, 2022 | 09:46 PM
Evilokc's Avatar
Engine: tbi 305
bottom of car to the ground? measuring 3 areas on each side i found the driver side is 1/2 inch lower at all measured sites
Old Oct 2, 2022 | 10:37 PM
Engine: 5.7 l98
Do you have adjustable panhard bar? Control arms both in the same mounts on each side?
Old Oct 3, 2022 | 12:15 AM
RestoRoc89's Avatar
Car: 1987 Iroc-Z/1993 Z28/2011 Corvette
Engine: 350 CI TPI/355 CI LT1
Transmission: 700R4/D&D Performance T56
Axle/Gears: 3.27 9-bolt/3.73 10-Bolt
Really basic question here … did you torque the suspension bushings (LCAs and panhard bar) with the suspension loaded / compressed? If not, the rubber bushings could be adding an uneven amount of preload. Ignore all of this if you have urethane bushings.
Old Oct 3, 2022 | 03:25 PM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Was it like this before you changed the rear end? Did you measure prior to changing the rear end?
I ask this for a reason, my car and my buddies 92 both sit lower on the drivers side. Mine I don't think has ever been removed and I have original springs. His rear end has never been out of the car and after he changed to lowering springs it still sits lower on the drivers side.
Old Oct 3, 2022 | 08:17 PM
Evilokc's Avatar
Engine: tbi 305
i have an adjustable panhard. bar. the rear control arms are tubular but not adjustable.
Old Oct 3, 2022 | 08:18 PM
Evilokc's Avatar
Engine: tbi 305
im sure i torqued the Panhard and sway bar with weight on the car. not positive about the rear control arms. i will check the lca tomorrow.
Old Oct 3, 2022 | 08:20 PM
Evilokc's Avatar
Engine: tbi 305
i didnt measure it before but i never noticed it was lower one side. it certainly wasn't low enough for a tire to rub.
Old Oct 6, 2022 | 05:39 PM
Evilokc's Avatar
Engine: tbi 305
i released the suspension and re tightened and its fairly even now. i appreciate the suggestion. the car does sit lower now though. has anyone noticed a ride height change with the 4th gen rear end swap?
Old Oct 12, 2022 | 07:54 AM
Abubaca's Avatar
If you're looking for a little extra height, 4th gen spring isolators will give you about 3/4" of an inch extra height.
Old Oct 12, 2022 | 03:30 PM
vorteciroc's Avatar
Top Answer: 1
The Rear Axle Assembly or the Uni-Body are most likely a little tweaked.
Old Dec 2, 2022 | 08:13 PM
Morphues's Avatar
Car: Looking for a 91-92 camaro.
Engine: Collecting for ls swap turbo
Axle/Gears: 9 bolt 3.27
When I do suspension work. I always try to mark where each arm is positioned angle wise. That way when I put new in it’s ride height doesn’t change.
Collision repair tech. Most of what I do it wrecked so doing that helps diag if there is other problems. Insurance doesn’t always want to buy what we tell them.
Old Dec 3, 2022 | 12:29 PM
Evilokc's Avatar
Engine: tbi 305
I'm usually better about it myself. I was injured and getting help from my cousin and not paying enough attention. its all good now.
KNIGHTE
Jun 30, 2015 12:58 PM
bad86z28
Feb 25, 2014 11:16 AM
87350IROC
Sep 14, 2010 10:43 AM
devianb
Jan 2, 2004 11:15 PM
Ovrclck350
Jul 1, 2003 01:43 AM
