Cracks in frame
Old May 5, 2023 | 12:17 PM
84StarshipBerly's Avatar
Car: 1984 Camaro Berlinetta
Engine: 350 sbc .60 over
Transmission: 700r4 2800-3000 Stall
Axle/Gears: 7.5" 28 spline axles. 3.42 gears
Cracks in frame
So I have found cracks in my subframe near the steering box. Wanted some opinions on if it could maybe just be welded and put some steel or if it needs to be cut out and replaced by a shop. I ordered a wonderbar for the car as well to prevent this in the future and to hopefully keep it from cracking even more until I get it fixed. Appreciate any thoughts y'all have.
Old May 5, 2023 | 09:53 PM
Firebirdwade's Avatar
Car: 1989 Pontiac Firebird
Engine: 383
Transmission: WCT5
Axle/Gears: 3.23Posi
Re: Cracks in frame
I see nothing there which could not be repaired if done right. Drill a small hole at the termination points of any crack, weld up the cracks. Grind the welds smooth. Next, plate the frame with some steel of the same or greater thickness than the factory material. 14 gauge? 11 gauge? whatever that is. Weld it all up nice, maybe put some holes in the reinforcement plate for plug welds to tie it all in more. Grind it all smooth and paint it dull grey to match.
That's what I would do. Probably not the right way, but it works.
Old May 7, 2023 | 01:14 AM
Re: Cracks in frame
Thanks for the advice! Glad to know that it seems repairable. Helps a lot to know how to go about it. Will update with pictures when its repaired!
Old May 8, 2023 | 10:40 AM
John in RI's Avatar
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Cracks in frame
Besides a little welding to fix those rips, you need to find and install a set of crossmember-to-frame rail brackets. There's also a 3rd bracket behind the fender liner that also adds extra support to the steering box.
Your problem was common with the 82-84 Coupes and Berlinettas because these brackets were not used. IIRC beginning an 85 Chevy recognized the problem and added these braces to all Thirdgens. ( The "rod" in the picture below is another added brace that was used from the pass side hood hinge to the firewall lip )
Old May 8, 2023 | 01:04 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Cracks in frame
^^^^ what John said. He is also eluding to the Wonder Bar. Search for 3rd gen camaro wonder bar and you will find many examples and explanations.
Old May 8, 2023 | 05:18 PM
Re: Cracks in frame
Thanks a ton! I didn’t know there was even more bracing besides the wonder bar. Definitely going to get those asap. Trying to get the cracks welded up this week hopefully. I’m also at some point going to get subframe connectors for the car which will hopefully help as well.
Old May 10, 2023 | 07:18 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Cracks in frame
@John in RI I've had that 3rd bracket in my face for the mare than 20 years and never thought anything of it. Now I know
Keep on browsing these forums, you never know what you are going to learn.
Old May 11, 2023 | 09:25 PM
Re: Cracks in frame
Got the cracks welded up today and its all fixed. The weld aren't winners in the looks department but they'll do for me. No shops wanted to do it so it came down to me and my buddy doing it in his driveway on jack stands and repaying him in a new extension cord. We welded up the cracks just how firebirdwade said and put some flat steel on for some extra support. Much better deal than the one shop trying to charge me $4000 to put a whole new subframe for such an easy fix for someone with lifts but oh well. I also installed the wonderbar and I'm waiting for the brackets that John showed to arrive and then we will be back to good. Really appreciate all the help guys!
Old May 13, 2023 | 04:24 AM
83 Crossfire TA's Avatar
Re: Cracks in frame
Funny how things change... back in the day that was a reason to condemn a car and send it off to the JY... now people are fixing them.
Old May 14, 2023 | 12:19 AM
Re: Cracks in frame
Final update on this thread. I got all the brackets on that John showed. Came out great! Need a different bolt for the one so just ignore that lol. Next will be subframe connectors and suspension and get the underneath all good looking. Thanks a bunch guys!
Old May 14, 2023 | 07:05 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Cracks in frame
Good work
Old May 31, 2023 | 08:01 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Re: Cracks in frame
this was common issue on early cars, factory added the bracing later IDK why Wonder bar" was IROC only that and STB added it will drive like a different car- really! its amazing how much load the PS box exerts on suspension.thats what causes the cracking. My 90 Suburban had same issue a buddy came and welded her up and same issue nothing to stop rails from moving.
mhpoff2001
Members Camaros
Jun 11, 2023 10:37 AM
bad03chief
Sep 6, 2019 11:58 AM
beansandmia
May 16, 2016 10:49 PM
C Murda
Aug 25, 2005 03:17 PM
GregN
Feb 13, 2002 07:13 AM
