Torque arm
Old Aug 20, 2023 | 08:31 PM
19eighty4_z28's Avatar
Car: One Chevy built in the 80s
Engine: 5.7 crate
Axle/Gears: Quick performance 9” 3.70
Torque arm
I’m not even sure I’m calling this the correct name but…I have my torque arm removed, got a new bushing and IT IS TIGHT AS HELL. I can’t get the clamps back round it. Anyway the trans is getting replaced soon so not worth my time to fight with it….or is it? Question…can I move the car on and off a trailer without installing this thing? Or will it cause issues?
appreciate any help
edit - pushing the car on and off a trailer
Old Aug 21, 2023 | 09:22 AM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Re: Torque arm
You will be fine pushing the car without it. Just don't try to drive without it.
Old Aug 21, 2023 | 10:07 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Torque arm
If the driveshaft is still in it you will be placing a lot of load on it, specifically the u joints. Did you buy the correct bushing? Did you lube the bushing? If it were me, I'd put the old bushing back in before you move the car. The rear pivots hard when you start remove the torque arm.
Old Aug 21, 2023 | 11:58 AM
Engine: 5.7 crate
Re: Torque arm
Yeah it’s the correct bushing and yeah I lubed it up before installing. I did see hawks has an aftermarket one for 85-02…will that not work on a 84? I’m confused by this as well. It fits perfectly in place and lines up great. As mentioned the brackets will not go around it
Old Aug 22, 2023 | 05:11 PM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: Torque arm
Instructions for install:
17https://www.energysuspensionparts.com/installation_instructions/energy_suspension/17126.pdf126.cdr (energysuspensionparts.com)
The reason why I posted this, the inner bracket locks into the outer bracket (in the transmission), I think I used a small pry bar to apply force too the inner bracket to close the distance and start the bolts in the thread.
Old Aug 22, 2023 | 08:05 PM
Re: Torque arm
I used the biggest pair of Channellocks I could find. Might even have used a C-clamp on that one.
Old Aug 27, 2023 | 08:59 PM
Engine: 5.7 crate
Re: Torque arm
Pain in the @ss but it’s in there. Can’t speak to any other year than 84, but if you put a strong clamp on the top and bottom of the bracket to compress it a little bit it’ll go back together. Shave the rivet heads off and pull out the two little shims that held the factory bushing. That millimeter or two made all the difference. In my opinion unless yours is trashed or your building a rocket probably one of those things one should leave alone.
Old Aug 27, 2023 | 10:15 PM
Re: Torque arm
esc
Aug 22, 2023 05:04 PM
watajob
Mar 26, 2011 11:35 PM
Goldenbullet44
Apr 15, 2010 01:04 AM
Cruz'N Bruz'R
Oct 1, 2005 12:33 AM
