Anyone have experience with Moog 5660 or 5608? (Tried 5662 & 5658).
Old Nov 19, 2023 | 02:34 PM
777Shock777's Avatar
Engine: 5.7!
I'm trying to find which Moog springs to run on my 88 GTA - I have returned it to stock and am wanting a stock-ish height.
I've tried:
Moog 5662 (706lbs) - These sat just a bit too high for my liking, cutting them made the ride too harsh.
Moog 5658 (579lbs) - sat just barely too low, putting weight on fender would compress to bumpstops. Rode nice/bouncy.
Does anyone have input on 5660s (639lbs) or 5608s (420lbs taller load/free height)?
Moog's website recommends 5662 w/16" wheels & 5608 w/15" wheels so I'm curious if anyone has any input on that too?
Old Jan 3, 2024 | 05:52 AM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Re: Anyone have experience with Moog 5660 or 5608? (Tried 5662 & 5658).
Wish i could remember what i came up with when i reseached that some years back.
Old Jan 3, 2024 | 06:23 AM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Call Sam Strano.
stranoparts.com
Old Jan 3, 2024 | 07:22 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Moog springs are designed to have 11 inch compressed height under the weight listed on their website. Those weights are sprung weight on springs, not the weight on tires. You'll end up sitting too tall if you use the scale weight of the vehicle.
Old Jan 6, 2024 | 02:25 PM
taguy16's Avatar
I've always felt Moog springs sit the car way too high for the model they list for your car's options (A/C, etc). It's kind of a crap-shoot finding ones that you like the ride height and feel of.
Old Jan 7, 2024 | 05:16 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Back in 2020 I crawled the Moog website for every spring tied to any 82-92 Firebird and found 13 part numbers for front, 2 part numbers for rear. I just crawled their website again today and I'm shocked how many of those part numbers have been eliminated.
Old Jan 7, 2024 | 07:13 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I've tried:
Based on Moog's published spring specs from their website, https://www.moog-suspension-parts.co...il_springs.asp
Static height with Moog-5660 will be right in the middle between Moog-5662 (taller) and Moog-5658 (lower).
Out of curiosity, how did you find that Moog-5660 part number?
Moog-5608 will sit taller than all those unless the car is on the very heavy side. Even then it will never sit as low as Moog-5660.
Old Jan 9, 2024 | 10:24 AM
Axle/Gears: Stock
Hey OP check out my older thread - 'Spring rates for Moog 5660......'
Old Aug 25, 2024 | 06:54 PM
rhyno91's Avatar
Car: 1988 Pontiac Formula Firebird
Engine: None
Transmission: None
I've tried:
You have the factory 350 in this car, correct? I am spring shopping for my iron block LS swapped Firebird and I am thinking the 5658 might be what I need since the LS is lighter than the Gen II small block.
Old Aug 25, 2024 | 07:00 PM
Roorancher's Avatar
Engine: 5.0/5.7 LT1
I'd try asking Sam Strano, at stranoparts.com.
He's primarily a 4th Gen guy, but I'll bet he can help and he won't steer you wrong...
Old Aug 25, 2024 | 07:03 PM
rhyno91's Avatar
Engine: None
Transmission: None
Thanks, I will check in with him when I get a chance.
Old Aug 25, 2024 | 07:52 PM
Generally, new springs will sit WWWWWWAAAAAAAAAAAYYYYYYY too high at first, butt will settle in over time. The Moog springs behave much like the OE ones did, only, they don't sag so much as the years go by.
Might want to check out this thread and see what these cars looked like when they were built.
https://www.thirdgen.org/forums/hist...od-1986-a.html
Old Sep 6, 2024 | 10:45 AM
Engine: 5.7!
Sorry for not updating, I installed 5660 springs with KYB AGX adjustable struts.
I found the ride is not as harsh and sits at a good spot, about 27.5" on the fronts.
(Rear is Moog CC635 with 4th gen isolators).
The fronts are a little bouncy at times, trying to find the best setting for the AGX's.
Old Sep 11, 2024 | 06:00 PM
rhyno91's Avatar
Engine: None
Transmission: None
Thanks for the update. I think I may try the 5658 springs on the front since the LS is a little lighter than the small block. Are the 4th gen rear isolators thicker than the 3rd gen?
Old Sep 12, 2024 | 04:57 AM
Engine: 5.7!
Yeah 5658 will probably work well for you with the LS.
Yes I believe they are an inch or so taller, the rear of my car sits at 28.5" roughly.
Old Sep 13, 2024 | 10:08 PM
rhyno91's Avatar
Engine: None
Transmission: None
I know the current trend is to lower these cars to the ground, but I think yours looks fine. Thanks again!
Old Sep 14, 2024 | 04:13 PM
Engine: 5.7!
Thank you! I love the original ride height of these cars.
Good luck with your install!
severe97
Apr 2, 2021 01:04 PM
justins920
Apr 15, 2007 08:16 PM
jrg77
Jun 10, 2004 08:03 PM
NuclearPwrIroc
Aftermarket Product Review
Apr 11, 2003 09:27 PM
paul russell
Mar 27, 2003 08:01 AM
