Engine and Transmission Mounts
Car: 1991 Camaro RS
Engine: 5.7L L98
Currently weighing my options for new transmission mounts and engine mounts. My project is a 1991 RS with a stock 305. The motor is being swapped out for the 350 L98. A lot of the stock rubber is shot due to the car sitting for the last 10 years. I am wondering what the viable options are for poly mounts for both, seeing as how most things are no longer on sale. I am also wondering what torque arms are good options today. Any help would be appreciated
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Engine and Transmission Mounts
If it's a stock L98 you can get by with stock replacement parts. The stock trans xmember is just a simple stamping but a poly torque arm bushing would be a simple replacement. The torque arm itself is also just a simple stamping so no other "rubber" there. Stock replacement motor mounts are also just fine to use. The rest of the suspension should be gone over and anything worn or busted replaced.
TLDR:
Replace motor mount bushings and torque arm bushing. Everything else is not related to the swap, but should be gone over for repairs.
Car: '90 RS
Engine: 377 LSX
Any aftermarket torque arm would be an improvement over stock. Founders has a really good unit for the cost. If you plan on future mods and or lowering the car, look at an adjustable units.
UMI, BMR, Spohn, Founders, all make solid torque arms.
Car: 1991 Camaro RS
Engine: 5.7L L98
TLDR:
TLDR:
Car: '90 RS
Engine: 377 LSX
The L98 is stock but I plan to do a rebuild. I was planning to do a ZZ4 cam and do a full tear down just to inspect everything. Would upgrading to poly bushings for the motor and trans mounts be worth it at that point or do you think that the stock replacement mounts will hold up?
Car: 1991 Camaro RS
Engine: 5.7L L98
Suspension wise I was looking into the Eibach Pro-Kit springs as well as Koni Yellows for shocks. The car was my father’s car so I want to take my time and build it up right. I definitely plan on using an aftermarket torque arm I was just debating on several different brands. I was leaning towards the UMI one but also saw the Spohn one and several others and didn’t know if it really made much of a difference between brands.
Car: '90 RS
Engine: 377 LSX
Car: 1991 Camaro RS
Engine: 5.7L L98
Your plan is solid and since you are doing basic bolt-ons, any of those brands will be more than adequate. I personally have used something from all of those brands and never had an issue when using a stock style replacement. One thing to consider are sub frame connectors. I would install those before any other modification. They do vary in complexity but any set is better than none. These cars are very flimsy in between the front and rear sub structures and it only gets worse when you improve the suspension before addressing this weakness.
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
A stock 28 spline rear end will be fine with your build. They are a lot stronger then people give them credit for. And yes they are weak.....compared to a 12 bolt.
Car: 1991 Camaro RS
Engine: 5.7L L98
89 Iroc Z
Dec 23, 2003 11:23 PM
