Clicking??
Old Mar 9, 2002 | 02:45 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Clicking??
Sometimes when I make sharper turns either left or right, I get this click from the front suspension. What is this?? Thanks!!
Old Mar 9, 2002 | 10:00 PM
Administrator
I know some1's got to know this here, it must be an easy question for u suspension guys!!
Old Mar 10, 2002 | 06:07 PM
z28camaro396's Avatar
I'm not sure what it is, but I can tell you that a friend of mine has the same problem with his "91 RS. It doesn't seem to be affecting the car at all though so maybe it's just some small little technical thing.
Old Mar 10, 2002 | 09:55 PM
dans87ta's Avatar
Car: 87 trans am, 93 full size blazer
Engine: 5.0, 5.7
Transmission: A4
It might be the brake calipers/pads. I had the same problem on mine. I think there are some tabs that you can bend or something to get rid of it. I just replaced my pads, and its fine now. If its this, its not a problem, just an annoyance.
Old Mar 10, 2002 | 11:08 PM
Administrator
Yes, it still corners the same but clicks alot. It is annoying.
Old Mar 11, 2002 | 12:48 PM
Administrator
Any1 else have this??
Old Mar 11, 2002 | 09:12 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Yup. I have the same problem on my 92 RS. It makes an annoying sound when the wheel is turned all the way. I wouldn't describe it as a clicking sound, but I don't know how else to put it in words. The car has had it since I've owned it, which is about 2 yrs.
Old Mar 11, 2002 | 10:26 PM
dans87ta's Avatar
Engine: 5.0, 5.7
Transmission: A4
thinking about it, I always had this problem on my 91 camaro, no matter what I did, and I did have it on my TA too, but i changed the brake pads and it went away. Thats weird.
Old Mar 12, 2002 | 01:18 PM
Administrator
Hmmmmph, I could use new brake pads. I don't get how that would fix that click sound when cornering though.
Old Mar 12, 2002 | 01:50 PM
dans87ta's Avatar
Engine: 5.0, 5.7
Transmission: A4
Well, the clicking I had, was the tabs on the brake pad were rubbing on something when I cornered. It was catching on something, I dont know what though. But like I said before, I heard you can bend the tabs on the pads, and it should go away. I didnt know exactly what to look for, nor did I want to bother since I needed new pads anyway, so I just got new ones. Search the board for this and you will probably find something. Sorry I'm not more help!
Old Mar 13, 2002 | 04:22 PM
86T/Anjsux's Avatar
I have the same problem...but in the rear. Been going on for about a year now. happens when Im cruising bout 25-30 mph.....*click click click*...So I jacked up the rear, took off the wheels ,put it in gear and ....nothing. suspension must have to be compressed or somethin. Anyone else have THIS problem???
RS Reaper
Oct 17, 2018 07:52 PM
Linson
Oct 1, 2015 09:50 PM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
