Help with Caliper...
Old Apr 8, 2002 | 08:46 AM
khellendros's Avatar
Anyone know any possible reasons that there would be a brake fluid leak where the rubber tube enters the caliper on the left driver side? I just reinstalled a new hose and a new caliper, but it leaks from the bolt. Any help appriciated, Thanks.
Old Apr 8, 2002 | 10:06 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Did you install the 2 copper O rings onto each side of the new hose? The bolt goes thru them... that's the seal. You should have received 2 new ones with the caliper.
Old Apr 8, 2002 | 02:13 PM
yea, i installed both of those
but it still leaks? How tight should i make the bolt? Thanks
Old Apr 8, 2002 | 02:35 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I couldn't find any torque specs for it, just try snuging them up some more. If the washers and hose and caliper are new it shouldn't leak. How bad is the leak. Did you install each hose on the correct side, I don't know if this is possible or if it would even cause a leak, just a guess
Old Apr 8, 2002 | 03:11 PM
Its leaking, but only when u press the break. A steady stream with the brake pressed all the way down. I replaced the brake line running from the master cylinder to the rubber hose, replaced the rubber hose, replaced the caliper, replaced the pads, replaced the copper O rings, twice.... Torqued down the other bolt, harder, and it broke.... Bought a new bolt, torqued that down and it still leaks. I didn't cross thread the caliper, checked that. Just leaks when u press the brake. Not a clue, but if anyone else knows. Please, Thanks for the help
Old Apr 9, 2002 | 01:24 PM
Florida Bird's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
It's possible that the new caliper is bad. Is the caliper new or rebuilt? If it's rebuilt the threads may have been damaged when they cleaned the caliper. I just did my brakes and it took 3 calipers to get one for the left side that didn't leak.
Old Apr 9, 2002 | 01:49 PM
Then thats probally it. I have tried everything... redo all hoses and washer.... over 2x. I didn't retry the caliper, but now that i think about it, it is a "Remanufactored Caliper." I knew the price was too good on that... $9.99 w/ a $13.95 core. I'll never go remanufactored again lol
Old Apr 9, 2002 | 02:24 PM
Engine: 305 TBI
I used to work for a company that rebuilt calipers. I saw things done there that would make you never want to buy a rebuilt caliper. Re using old seals because they didn't have the correct new ones. ALL caliper were to be pressure tested with air, but if they were behind on the count for the day only a few would get tested, and the air hose had a rubber tip that was put in the line hole right where you are leaking.
Old Apr 9, 2002 | 02:54 PM
Thats crazy. I just took the old one back and bought a new one. It holds pressure, so now i just have to bleed them. Thanks for the info man, i was really gettin discouraged :hail: :hail:
WILL85IROC
Brakes
Oct 4, 2013 09:27 AM
Primetime91
Brakes
May 12, 2010 07:47 AM
FireInMe17
Brakes
Feb 28, 2010 11:48 AM
InfernalVortex
Brakes
21
Dec 4, 2007 04:15 PM
dimented24x7
Brakes
Sep 30, 2006 09:03 AM
