14 sec or faster TBI cars. Post timeslips and modss
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
There seems to be only 1 guy on the entire TBI board that ran a decent time in a N/A 305 TBI on the fastest TBI thread, 14.2@96mph. Post times and mods, NO BS. I'm very interested in what a TBI can actually(timeslips) do.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
13.8/102mph(Oct 01)
2.195 60"/.7sec RT
3.07 rear/Stock Tires at 35psi
Xfire Corvette/4+3 Trans/Z-51
2.0" TB's(Now 2.13")
Comp Cams Hyd Rlr(Now using 1.6rockers)
TPIS Headers
TFS 23d Heads
MSD 6A
Ported and EH'd manifold
Stock Injectors(Now 80# Parallel Plumbing)
K&N Air Filter
All Emissions operational and passed Illinois drive cycle
2.195 60"/.7sec RT
TPIS Headers
TFS 23d Heads
MSD 6A
K&N Air Filter
14.209 @ 95.5mph
ultimate tb
edelborck tbi intake
edelbrock centerbolt heads (60cc chamber, 2.02/1.60 valves)
roller tipped 1.6 rockers
edelbrock tes headers
no cat
borla cat back(open plate)
posi w/ 3.54 gears
2000 stall convertor(waaayyy too small to get the job done)
transgo shift kit
cam and chip were stock
chip woudl have easily put the car into teh 13's and spending all taht money on heads was a mistake, a cam woudl have been a much better choice.
later
tim
ultimate tb
no cat
posi w/ 3.54 gears
transgo shift kit
later
tim
Car: 91 RS
Engine: 350 TBI
NJ Speeder : So would have gone with the LT1 cam??? or something different?
I hear that the S/R Torquer heads with the LT1 cam is a nice setup, but I can't confirm that. How was your daily commuting affected? If I could get into the 14's that would be sweet, but I don't think I can use that tall of a converter for my daily driving. One last thing....do you know anybody who would do the ultimate tb mod for me? I keep sending that Camaroracer1992 emails, but he never responds.
Engine: LS7
NJ Speeder, You said stock cam with those heads 2.02/1.60" valves? No problems with the big valves and the cylinder walls? I wonder how much clearance there was left, for a bigger cam.
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Originally posted by vortecss
Don't waste your time on the " ultimate " TBI mods. They are worthless.
Grinding the tbi, shaving the throttle shafts and advancing my timing 6* gave me .4 and 2.5 mph in the 1320 boogie.
I have time slips to back that up, too.
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
ok, so i'm guessing he doesnt feel like justfying his response. but the ultimate mods are not a waste as everyone else agrees with. granted, on their own, they may not make much of a difference, but they'll help when you really start making other changes
Car: A Camaro
Engine: Weak
Transmission: Weaker
I think someone should make a
3rd generation timepost registry!
or something like this so that every time this question comes up, someone can just be like "check out the registry." It would be convenient to have altitude, 60', method (strip vs. tazzo/gtech) and mods. I would do this but I have no idea how to make a web page although I could make a spreadsheet in Excel that we could link to and store it on the web. I think this would be very helpful in showing what TBI can do and for how much money.
sorry I posted the same thing in two messages but it seems like such a simple thing could save so much time, just like Eric's website.
iroc22, you hit it right on the head. i didn't have the opportunity to mock anythign up, but i mesured the heads and compared it to the cyl bore before i bough tht eheads. it really works out very nicely. i do think that saying shrouding doesn't occur until 560 lift may be pushing it though. the turbulance created by the loss of spce will actually occur at lower lifts and cause a drop in intake charge draw. yes, you can go with a huge cam for racing, but for a driver i woudl try to stay below .500 lift, preferably below 480 with big vavles. the interference does not cause a loss of rpm or ability to make power, just a loss of vacuum that will call for a higher idler, poor idle quality, and can cause a loss of throttle response.
vortecss, the ultimate mods have been proven time and againto be well worth the effort. i personally gained a full mph of trap speed from my first tb(which was very pooly done). teh tb's i can put otu now that i have practice are prolly worth a lot more(i have done about 20 of them)
gunny highway, i wodl have liked to find a LT4 cam(a little bigger tahn teh LT1 cam). the LT1 cam will certainly get the job done though, it is a proven piece and shows a big gain every time. you can go with more cam too. a few guys have messed around with zz4 cams and other grinds intended for a bit more rpm with great success. just remeber, teh bigger the cam the more time you are gonna spend working on getting eth whole power band right. with the stock heads or aftermaret small valve heads you can easily get into teh 520 lift range and keep a good idle under 750 rpm.
the car drove pretty good mos tof the time. since i didn't have a chip the car ran rich at idle and loaded up a bit if i sat in traffic. teh idle was pretty good and mileage stayed aroudn 20 on the highway.
a few things i woudl liek to see everyone look out for in all this though.
1. et is abotu teh car, mph is about the engine. all the power in theworld is worthless if you don't hook. the first time i went to the track with this set up i went 14.8's. i got a set of hoosiers and went 14.3 the next time out. 14.2's cam after messign with teh base timing and fuel pressure.
2. teh ecm is the key to a happy engine. if you can keep the chip tuned to waht you have in the engine, even if the engien is stock, you will see a huge improvement in power, throttle response, and mileage. you want a real custom chip, not some off the shelf or mail away junk. you can not tune your car from a chip company submission slip, you need to data log and adjust from there.
later
tim
later
tim
Hey I'm no expert
Ummmmmm, I had a 14 second TBI Formula without the "ultimate" mods.
It's all in your head timeslips or not, The flow characteristics of the TBI base are really messed up with these mods. The mods to the blades themselves may work but grinding the flow vains on the top is a bad idea. These direct air into the TBI base. If you remove them the result is crossflow turbulence.
vortecss, i don't know where you are coming from on this one. what othe rmods did you have on tha tmotor? did you try that eengien with an ultimate tb?
unless you have made before and after comparisons on the same motro you can't even begin to think anyone is gonna buy into what you are saying.
i have seen my car and several others before and after ultimate tb's. i can tell you for a fact that a stock or very mild(exhaust/air cleaner) LO3 will gain a whole mph of trap speed from it.
later
tim
later
tim
Engine: LS7
I would like to see some other combos, but I can get a stock TBI to modify and I will post before and after times after i do it. The car is running 15.7 @87 mph with stock t/b on down to the cat. K&N filter and hooker 2 and 1/4" exhaust to 3" later. Looking for mid 15s with custom chip aka coolant temps in the less than 200* range instead of 220+ like I've been running
Well my name is Cody ring any bells?
I was the one who did all of the "duh" mods on my 1991 Formula TBI 5-Speed and ran a best of 14.9
And yes I have seen several variations of TBI mods at the dyno three months ago. It was an engine dyno too.
The only things that the "Ultimate" TBI mods did was throw off the powerband characteristics. And limiting top end power.
These tests were all performed to prove a point that some "mods" aren't really mods at all. We also tested the air foil, GM TBI Vortec kit and the larger TB's.
By the way the GM TBI Vortec kit had amazing results!!!!
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by BahamutRS
My car ran consistent high 16s with the mods in sig and the ultimate TBI mods. Must have had something wrong with her...
Car: 91 RS
Engine: 350 TBI
goodbye again cody.
later
tim
The stock manifolds and cat. 2 1/4" lol it's pathetic compared to the 3" on my T/A
Engine: LS7
yeah I know, but i have a free set of edelbrock's, 3" cat and hooker cat-back sitting in NY in my other car that I'm going to swap during winter break.
It sucks having one car with a blown up 305 sitting in NY and me living in FL right now.
My plans are to take the exhaust mentioned above, the TPI heads(home port/valve job) 1.6RR, I think a LT1 cam, (crane 2032 I think is a little big, although it worked well in my TPI w/o a custom chip) I haven't decided which intake to go with yet the TBI(edelbrock) or a carb w/ adapter. This car WILL remain very streetable, A/C, some emissions, my T/A was still a daily driver, A/C, full emissions, but I wouldn't want someone else driving(no power below 1500 rpm, hard brakes near idle, etc.)
Car: 91 RS
Engine: 350 TBI
Engine: LS7
someone correct me if I'm wrong, but I'm pretty sure that TBI heads have a hump in the casting to induce swirl(kill flow) and more than likely weaker valvesprings(mine are aftermarket anyways)
Hey guys, ok i just ran my car about a month back, i ran a 14.16 at 96mph with a 2.2 60ft, but then again my car is a 350 tbi, so i dont know if all my info is relevant to this thread, all my mods are posted in my sig. I think i can hit 13's fairly easily in better weather, and with better tires, the ones i raced on were really bald.
Car: 91 RS
Engine: 350 TBI
Originally posted by iroc22
Yes they have huge valve shrouds that hinder flow big time. They have nice big valve openings, but that doesnt make up for the cast in swirls and valve shrouds.
Im using a 8746 computer with a custom burnt chip i had done by brian harris, he is on this site, and he is pretty ***, he will work with you on getting a chip done to your specs. The car might not be perfect, because it will never be perfect without data logging it, but he made it run a ton better, and i was very satisfied. The heads are just the stock L98 heads.
Originally posted by Gunny Highway
Can those be removed by a machine shop?
Linson
Aug 21, 2015 02:12 PM
