Advice On Performance Upgrad??
Old Oct 13, 2002 | 01:55 AM
88TRANS's Avatar
I HAVE ACQUIRED AN 86 T/A WITH A 305 TBI ENGINE , STOCK TRANS AND EXHAUST. THERE IS 90,000 K ON MOTOR. CAR IS COMPLETELY STOCK AND EXTREMELY WELL MAINTAINED. ONLY AFTERMARKET ITEM IS A K/N AIR FILTER. WHAT WILL GIVE ME THE BIGGEST BANG FOR MY BUCK WITH RESPECT TO MODS UNDER THE HOOD/TRANS. IM NOT LOOKING TO GO CRAZY WITH THIS BIRD JUST LIVEN IT UP A BIT. 305 TBI IS NO SCREAMIN DEMON. ALL INPUT IS APPRECIATED. THANKS GENTLEMEN
Old Oct 13, 2002 | 09:32 AM
1989camarorsrs's Avatar
I would get a 3 inch cat back exhaust. Our stock 2 1/4 inch piping sucks. Hooker, slp, flowmaster, edelbrock will all work welll and give a very nice tone. U said k & n filter but make sure u do the open element mod its good for about 5-10 hp. heres the link http://snflupigus.tripod.com/tech/op...tep1/step1.htm
All this for a total of about 300 bucks for a total of around 15-20hp. I would also suggest buying a lower temperature fan switch. Tbi runs like **** at 220-240 degrees. Another 40 bucks or so .
Old Oct 13, 2002 | 09:33 AM
Oh yea and if u want more out of the catback exhaust another 110 dollars for a high flow 3 inch catablitic converter.
Old Oct 13, 2002 | 02:54 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Advice On Performance Upgrad??
Originally posted by 88TRANS
I HAVE ACQUIRED AN 86 T/A WITH A 305 TBI ENGINE , STOCK TRANS AND EXHAUST. THERE IS 90,000 K ON MOTOR. CAR IS COMPLETELY STOCK AND EXTREMELY WELL MAINTAINED. ONLY AFTERMARKET ITEM IS A K/N AIR FILTER........
Uh...... I can tell you that if it's really TBI, then it isn't stock at all. Make sure it's not a carb. TBI wasn't put on our cars (stock) until '88.
AJ
Old Oct 13, 2002 | 03:46 PM
vjo90RS8's Avatar
Car: 2002 Z28
i think he meant to say that he has an 88 Trans AM cause his user name is 88TRANS
Open Element, headers, hi flow cat, and 3" cat back should be your first mods
Old Oct 13, 2002 | 04:43 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
Yeah it is got to be a carb cause like the man said they didnt come out with tbi till 88 so that would make it a carb
Old Oct 13, 2002 | 06:04 PM
88TRANS's Avatar
SORRY ABOUT THE TYPO GUYS. YOU WERE ALL CORRECT . ITS AN 88 T/A WITH TBI. I WENT TO GO LOOK AT A 86 EARLIER IN THE WEEK AND HAD IT ON MY MIND. SORRY ABOUT CONFUSION KEEP IT COMING. THANKS
Old Oct 13, 2002 | 09:49 PM
AJ_92RS's Avatar
What he said but in this order.......
Open Element, 3" cat back, hi flow cat, then headers. This is usually the easiest on the wallet and does the most good in that order.
If you can do all of them at once, by all means do it.
AJ
Jorlain
Oct 8, 2015 01:57 AM
gta90
Sep 15, 2015 04:00 PM
angel2794
Sep 8, 2015 06:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
z28guy134
Sep 1, 2015 11:50 PM
