Cam that wont break $h|T
Old Oct 14, 2002 | 05:27 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
my car decided to grind out a cam bearing sooo it's time for a new cam.
I want to put a little preformance cam into it but as I am broke nothing else in the motor is gonna change ('cept for the lifters of course) what I really wanted to know is how big can i go before I start needing valve springs?
Old Oct 14, 2002 | 08:53 AM
TBI305Camaro's Avatar
if you have a roller cam/motor you dont even have to change the lifters.
Old Oct 14, 2002 | 02:53 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
You can go with the LT1 Z28 cam with the stock valve springs. You can gain some peak rpm's with a little stiffer spring but the cam will run ok with the stockers.
Old Oct 14, 2002 | 05:06 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
What kind of lift / duration is the stock lt1 cam? the cams i'm looking at are summit kits (can't beat 80 bucks for a cam kit)
p/n dur @.50 lift
sum-1100 184/194 .368/.398
or
sum-1101 194/204 .398/.420
mabey a lil larger? I;m not really looking for a preformance cam - it's broke and needs fixin (the car will get a 350 when fast time comes) and $80 for almost everything i need is pretty good. It just looks like i might have to drive this biatch for a lil bit plus it will be cool to have finally done a major mod : )
Old Oct 14, 2002 | 05:08 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
doh just read my first post.... I ment a lobe - mabey a lifter?
Old Oct 14, 2002 | 07:24 PM
i wouldnt waste my time with those cams...they arent roller either so im not sure if it would work. lt1 cams are cheap...i got one for 31$ on ebay i dont know for sure if its a lt1 or not.
Old Oct 15, 2002 | 07:40 AM
<b>LT1 Cam:</b>The duration at lash point in degrees at .050" tappet lift (intake/exhaust) is 205/207; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is .447/.459. Valve lash is zero/zero and lobe centerline is 116 degrees._
Specs vary slightly year to year on lt1 cams but not enough to make a real difference. They are all a LOT more than TBI cams.
Old Oct 16, 2002 | 12:18 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Did the TBI 305 come with a roller cam in 88? I would be really really suprised if it did.
Jorlain
Oct 8, 2015 01:57 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
