how are TBI cams different?
Old Dec 27, 2002 | 09:15 PM
Belstain's Avatar
I keep seeing references to tbi cams, what is different? why won't any ol' cam work?
Old Dec 27, 2002 | 10:02 PM
NJ SPEEDER's Avatar
the cams are just hydraulic rollers, nothing particularly special about them. what you see when you look at application specific cams are usually very small step cams. they ae designed to work well with a stock computer or maybe an off teh shelf after market chip. those cams are pretty much a waste of time for what they cost.
later
tim
Old Dec 28, 2002 | 11:57 AM
Belstain's Avatar
OK so I can run pretty much whatever cam I want and the ecm can be reprogramed to handle it?
Old Dec 28, 2002 | 05:44 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i would keep it under 220 deg intake at .050
Old Dec 28, 2002 | 07:31 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Many people recommend keeping the lobe seperation angle LSA to 112° minimum to keep the MAP sensor "happy".
Old Dec 28, 2002 | 07:43 PM
c4boom's Avatar
Engine: l98 and lo5
yes it helps pull more vac this makes for better tuning
Old Dec 29, 2002 | 05:26 PM
iroc22's Avatar
When you see Fuel Injection cams for sale, the only reason they have received that title is because the LSA (in proportion to the duration) is designed to work with an ECM.
Old Dec 29, 2002 | 05:29 PM
CHEVYTOWN's Avatar
What is meant by dual pattern?
Does one need a dual pattern cam for EFI?
Or just as long as one has 12" of vacuum...
Chevytown
Old Dec 29, 2002 | 09:56 PM
c4boom's Avatar
Engine: l98 and lo5
i would shoot for 16-20" of vac on a street tbi car
Old Dec 29, 2002 | 10:00 PM
CHEVYTOWN's Avatar
Cool. Mine aint dual pattern but does have 15-16"...
Old Dec 29, 2002 | 10:26 PM
c4boom's Avatar
Engine: l98 and lo5
dual patt. cams are beter for stock heads and such you use them on a good set of heads and you will loos power some times
MustangBeater20
Oct 29, 2022 09:20 PM
junkcltr
Aug 2, 2019 11:12 PM
509 camaro fan
Sep 6, 2015 10:43 AM
z28addict8490
Sep 5, 2015 03:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
