4 barrell throttle bodies?
Old Jan 26, 2003 | 12:56 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
http://www.gtoracing.com/automotive/...d/throttle.asp
i can't find that on holley's website anywhere. does anyone know anything about it/have experience with it?
Old Jan 26, 2003 | 07:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 4 barrell throttle bodies?
This link lists most (all?) of the Holley EFI parts. It includes the throttle bodies.
http://www.holley.com/HiOctn/ProdLin...IA/FMSFIA.html
This is a link directly to the 900 CFM 4BBL TBI:
http://www.holley.com/HiOctn/ProdLin...A/500-16S.html
Price's are competitive to a new carb too.
RBob.
Old Jan 26, 2003 | 11:34 AM
gordo's Avatar
will this work with the factory computer,assuming a custom chip is added? I am building a big inch smallblock and would like to retain the looks of the lo3.
Old Jan 26, 2003 | 12:20 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
You need two additional injector drivers.
Read this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=154902
Old Jan 26, 2003 | 02:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Read this thread:
Yes to what Joby says, need two additional drivers.
There are two ways to do this. One is to add the two drivers internal to the ECM. The second method is to add an external driver box. Both are accepted practices. Just pick the one that suits your talents/requirements/needs and go with it.
This will work.
There are the National Semiconductor (www.national.com) LM1949 and then the OnSemi, used to be Cherry, CS-453 5-pin To-220 cased device.
I'd really like to see someone do this. On the DIY-PROM board a guy YELLOWBB(?) has done this. He isn't finished tuning yet, but it is working out for him. He is using a '747 w/an external driver box.
RBob.
Old Jan 26, 2003 | 03:48 PM
JPrevost's Avatar
Car: 91 Red Sled
The only reason I'm reluctant to go witht he 4 barrel TBI is the injectors. I was under the impression that they used the crappy injectors still. I've been getting better with solid works and the plan is to make my own injector pod that housed GM injectors.
Tough project.
Old Jan 27, 2003 | 08:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Tough project.
Don't know. I had thought they were the newer Delphi injectors. If they are the older ones then I wouldn't use it either.
The pictures do show the black plastic caps. I think that means that they are the old style. Oh well.
RBob.
Old Jan 30, 2003 | 04:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Just got it on good word. The Holley 4BBL TBI's also use the Delphi injectors. These are the 'good' ones. Holley has been using these for 2-3 years now.
I would use one of these TBI's.
RBob.
Old Jan 30, 2003 | 06:49 AM
JPrevost's Avatar
Car: 91 Red Sled
Cool! Then forget going to port injection.
Old Sep 13, 2004 | 03:36 PM
ben73's Avatar
RBob.
Why are these injectors crappy, and are the black caps a sure way to identify them?
I dug up this old post while searching on holley 900 4bbl stuff ;-)
Ben.
Old Sep 13, 2004 | 09:53 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Yes, the black caps indicate the old mopar style injector. Those injectors have a bad rep, seems mostly due to a short life span and poor spray patterns from what I have read.
The only experiance I have ever had with them were on my father's '89 ram, which came stock with a holley tbi (though the injector pod sits down much farther than the 670). Anyways, at 2XX,XXX miles, one finally went bad. But I'm not sure if they are exactly the same as the ones on the 4bbl tbi.
The Delphi's are possibly able to handle a 100psi, I'm not too sure about that, but someone stated that in a post a couple of weeks ago.
The other reason to go with a 4bbl tbi w/ the delphi's is that the unit also uses progressive linkage, which of course is a good thing given a way to tune it in. Maybe a tps % toggle to the external injector driver?
Also, the delphis use a side mount connector and no black caps, just for reference
Old Sep 14, 2004 | 11:49 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I ran one of these 4bbl throttle bodies on my 350 when it was still TBI for about 2 months, but I only used two injectors since they were 65lb and plenty for my bolt on 350. It worked great, but I was at the point where I needed some tuning in order to revv in the higher RPMs so I ditched it for a carb and added some more goodies to my engine. I actually still have the Throttle body, I tried to sell it for like $200 a while ago and nobody wanted it. I would defenetly reccomend it to anyone who is building anything bigger than a 305 and keeping it TBI.
Old Sep 14, 2004 | 05:37 PM
Engine: LO3;383tpi
With the right tuning, a holley 2bbl tbi will work wonders on any street driven 350 pushing out up to 400hp. Though I can only imagine how much easier it would be to tune in a 4bbl tbi w/ commander 950 on a high hp engine.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
