is this a good cam?
Old Feb 22, 2003 | 11:01 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
is this a good cam?
I want to buy this comp 252AH-12 cam and I just wanted someones input of the type of results I might get with it.
Following info on this cam kit;
-Lift(w/1.5 Rockers) intake=.425 exhaust=.440
-Duration(@.50) intake 206 exhaust 212
(Adv. Dur) intake 252-4 exhaust 206-7
-hydraulic lifters
-lobe sep. angle 112 degrees
-1000-5000rpm range
[B]Stock CFI 82 305 lu5 has following cam specs;[B]
[B]Lift[B] intake=.390 exhaust=.410
[B]Duration[B] intake 194 exhaust 201
This cam is going together with ported out stock intake manifold, ported heads, headers, 3'' exhaust, and ultimate tbi upgrade.
What might this setup produce; in horsepower? 1/4 mile?
Old Feb 23, 2003 | 01:05 AM
NJ SPEEDER's Avatar
it is a pretty mild cam, certainly an upgrade from teh stocker, but you coudl get a bit more cam adn gain a lto more performance for the same amount of work/money. you don't need to go nuts or anything, but a ported intake and ultimated tb's can definately handle mroe cam than that. i suggest looking at teh extreme energy 268h. it is a great all around cam, perfect for a strong street car.
later
tim
Old Feb 23, 2003 | 01:45 AM
2000_Eclipse_GT's Avatar
what about a strong emissions legal auto car with just ultimate TBI mods done?
Old Feb 23, 2003 | 11:05 AM
NJ SPEEDER's Avatar
with the ultimate mods and tunign you can add a cam and still easily meet your states emissions standards. since the emissions standards are basiclly rated on teh "waste" of you engine, a littl ebit of tungn is all it will take to get a mild cam to comply.
later
tim
Old Feb 23, 2003 | 12:49 PM
iroc22's Avatar
I'd look at trying to squeeze a bit more lift from that cam with some higher ratio rocker arms.
Old Feb 23, 2003 | 12:51 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
IM wanting to get a set of l98's head's for my 350 and have them ported and polished, then get the eldebrock tbi intake and put in a different cam. I want to put in 3:73 gear's and a 2400 stall torque converter too. But i need some one to recommend me a good cam for this setup too
Old Feb 23, 2003 | 03:27 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i would look for a little bit bigger cam
Old Feb 23, 2003 | 03:46 PM
Car: 89 Camaro RS
Engine: 355 TBI
I need some one to recommend me a cam. I know that i need a bigger one then i already have
Old Feb 23, 2003 | 04:44 PM
iroc22's Avatar
You'd get more answers if you started a new topic.
Old Feb 24, 2003 | 08:20 PM
Car: 82 T/A
The 268h high energy cam seems like it would be wicked for my setup. However one the comp cam website it says that the cam is designed for engines with 9:1 compression or less, mine has 9:5, it also says that the cam is designed for carburated engines, mines a cfi.
Were should I go from here?
Old Feb 25, 2003 | 07:40 PM
Car: 82 T/A
should I just ignore most of that and go ahead with getting that 268h cam. I heard somewhere about the lobe separation having to be 112 or 114 degrees for my 305 cfi.
IS anybody sure if this cam is compatible with my 1982 305 crossfire engine?
..and yes im going to keep the exhisting throttle body..
Old Feb 25, 2003 | 08:31 PM
iroc22's Avatar
It's not a bad camshaft but the 110* is going to give you some trouble.
I'd personally go with a dual pattern cam. 252AH-12 doesn't look too bad. Maybe grab some 1.6 roller rockers as well to bump up the lift figures.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
