differential
Old Mar 6, 2003 | 12:33 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
differential
what is the difference in the differential i have in my car and the 3 series differential by zexel torsen that SLP sells. is that a limited slip setup? (i do not have the g80 rpo code)
Old Mar 6, 2003 | 01:10 PM
iroc22's Avatar
The obvious difference is the SLP diff is a limited slip unit. It's a torsen-type of limited slip instead of the clutch type.
Old Mar 6, 2003 | 01:32 PM
Engine: LO3 and LT1
so is this differential a decent differential or should i buy a more expensive torsen differential theres one at the local drivetrain place for 220 the estimate that i got for the whole rear end setup plus a 342 rear end gear or 373 was $832 if i use their differential and get new berings with it does this sound like too much or is it a decent price
Old Mar 6, 2003 | 08:08 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
The SLP unit is a decent unit.....not neccessarily the best in terms of posi units, but its way better than your stock open unit. For the Price 99bucks you cant go wrong...just make sure you have 28spline axles since it needs em.
Old Mar 6, 2003 | 10:23 PM
Engine: LO3 and LT1
how hard would it actually be to do the gears myself or with someone who has set them up before i can get the tools for free and i know alot of people who have done this before but i was just wonderin because the cheapest place i have found so far wants 420 dollars for labor and im tryin to not spend so much but if i have to i will and also for the ring gears would you go with a 342 or a 373 ive been told good about both
Old Mar 6, 2003 | 10:29 PM
vrooom305's Avatar
410!!!
Old Mar 6, 2003 | 10:32 PM
Engine: LO3 and LT1
its a daily driver in the summer i dont want to watch the gass needle move after 50mph
Old Mar 6, 2003 | 10:36 PM
vjo90RS8's Avatar
Car: 2002 Z28
I drive 250 miles home (each way) about twice every quarter and i have not really noticed a difference in gas mileage after going from 2.73 to 3.73.
Old Mar 7, 2003 | 12:37 AM
ZRATED's Avatar
Slp unit is great for the price you can not go wrong there.
I have no problems with it:hail:
Old Mar 7, 2003 | 06:35 AM
Engine: LO3 and LT1
cool thanks i diddnt think the slp unit would be bad for the price i think the one they wanted to sell me was an eaton but if i can save 120 dollars i will
Old Mar 7, 2003 | 04:45 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
just make sure you have the correct axles to use it (28-spline) or you have a line on a set of them, because that $99 bucks could certainly creep up in a hurry if you have to change to 28 spline
Old Mar 8, 2003 | 12:08 PM
Engine: LO3 and LT1
all the descriptions say that 92 and above have 28 spline axles and i know its a 7.5 inch rearso hopefully it turns out
Old Mar 8, 2003 | 02:55 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
I think they say some 89s but all 90, 91 and 92's came with 28 spline axles. If you have a 90/91 or 92 then you will have the correct axles to use the SLP unit..if you have 89 it is unlikely since most 89's came with 26 axles.
Old Mar 9, 2003 | 02:41 AM
Charlo's Avatar
For the 8.5 10 bolt, GM went to 30 spline in 89. I dont know about the 7.5.
Charlo
Old Mar 9, 2003 | 08:43 PM
Engine: LO3 and LT1
what is a mini spool and what does it do is that like adding a locker to the rear it says that it is for open differentials
Veaceonee
Sep 29, 2016 08:15 PM
dbrochard
Jan 28, 2016 08:42 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
dbrochard
Sep 19, 2015 08:13 PM
