What cam should I use?
Old Mar 10, 2003 | 10:28 PM
bigearll's Avatar
What would be a good cam to put in my 305 crossfire? Thanks for any help.
Old Mar 10, 2003 | 11:07 PM
SilverSub122's Avatar
it seems to be a popular opinion (especially if you have to pass emmissions) to go with an lt1 cam. they give good power and can still pass smog
Old Mar 10, 2003 | 11:12 PM
bigearll's Avatar
Does it have to be any specific year in order for it to match up right?
Old Mar 11, 2003 | 12:02 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
No, all years will work from 94-97 from Z's or TA's. Although I have heard that the later years were slightly better cams in terms of performance. Also, when putting this cam in your 305 you have to cut down the dowel on the cam, you can just use a dremel cut off tool to do this.
Old Mar 11, 2003 | 12:31 AM
iroc22's Avatar
Hang on here I think most people here missed that you are running a CFI intake. The LT1 cam will not work.
Are you planning anymore engine mods in the future? We need to know a little more about your current and planned combo to give you cam recommendations.
Old Mar 11, 2003 | 05:11 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
the lt1 cams are rollers. his motor is not a roller therefore the cam will not work.
Old Mar 11, 2003 | 04:01 PM
bigearll's Avatar
So far there arent any modifications to the motor. But within the next couple of weeks i'll be rebuilding it. Are there any suggestions on what i should do? Thanks.
Old Mar 11, 2003 | 04:37 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Get good heads. I dunno what kind of heads you have but bigger valves and a port and polish would do wonders. A little bit bigger cam would be good too but I have know idear what goes well with CFI. BTW you might be able to find a 305 roller block for not very much and adding a roller cam would be v. good too. Along with porting the intake and headers and catback.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
