problems never cease
Old May 5, 2003 | 06:50 PM
SlowMaro's Avatar
ok, installed a performer manifold. when i start the car, it runs perfect, for ten soconds, then soon after, when i it the gas, slow revs, extreme loss of power, no mis firing, no rough running, runs SMOOTH ....just acts like a 6 cyl. this performer is non egr, could this cause the problem??? any ideas? model # 2101.
Old May 5, 2003 | 09:38 PM
25THRSS's Avatar
have you deleted the egr from the chip?
Old May 6, 2003 | 12:09 AM
SlowMaro's Avatar
nope/////
Old May 6, 2003 | 12:11 AM
25THRSS's Avatar
You need to do that. Check out here. He can do everything for you. http://www.tbichips.com/
Old May 6, 2003 | 06:17 AM
SlowMaro's Avatar
lol thats where i got my chip from a month ago, i emailed brian an d asked him wf could do it
Old May 6, 2003 | 06:21 AM
ctandc's Avatar
The EGR error will just throw a code, if that, it won't cause the issue you're having.
First thing is go back to basics. You installed an intake, so you had the distributor out as well.
Make SURE all the plug wires are installed correctly. It will shock you how "smooth" a V-8 can run with the plug wires off, but only at low RPM's. IF that checks out, make sure your timing is okay. This is the problem most of the time when the distributor has been removed.
HTH
Old May 6, 2003 | 02:49 PM
SlowMaro's Avatar
i dont think the dist is in wrong, it would run like crap if it was off wouldnt it,, i mean like, 8 degrees, or even 1 cyl....say, pointed at the #8 instead of #1
Old May 6, 2003 | 02:53 PM
25THRSS's Avatar
No, if it was off that much it wouldnt run. I think the egr could be a problem because if the computer thinks it's getting it when it's not then it will advance the timing and it won't run right. Your problem is in the timing definitely. Have you gotten your timing light back yet? If not, you need to do that now! There is no sense in trying to find out what the problem is until you fix what you KNOW is wrong with the car.
Old May 6, 2003 | 04:13 PM
SlowMaro's Avatar
ok i JUST got it back.....gonna set the timing to 8 degree advanced in a min...i was worried i put the dist in a tooth to far right of left, but thats easily fixed by turning the dist right?
Old May 6, 2003 | 06:53 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The erg not being disabled wont cripple the computer. It'll pull some timing but it will still run decently. The disty being off a little bit could be it, pull it out and stab it in again, shouldnt take but a few minutes just make sure you're at tdc on #1. A small vacuum leak might cause it, or maybe just a bad wire. Just re trace your steps, you'll find it out
Good luck man.
Old May 6, 2003 | 10:46 PM
25THRSS's Avatar
I didnt think the distributor could be off by a tooth, only 180 gegrees off. It only goes in 2 ways, right or 180 degrees turned around, or atleast this is my experience. Every one ive changed just dropped right in. Then you just adjust from there.
Old May 7, 2003 | 01:37 AM
SlowMaro's Avatar
nahthe oil pump shaft can be turned accidently and go in a tooth or so off, but you can turn the dist some and itll correct the problem
Old May 7, 2003 | 01:49 AM
25THRSS's Avatar
Turning the distributor will either advance or retard the timing. I don't believe you can turn it to get it in a different tooth. You know when it is down in there. If it's not in right it will not go down all the way. There are only 2 ways you can have it go down in: the right way or 180 degrees off. Is that what you were saying? I could have misunderstood what you were saying though. If so, please feel free to correct me.
Old May 7, 2003 | 01:54 AM
SlowMaro's Avatar
the flat head shaft deal on the oil pump turns very easily, it can accidently get turned a lil and the dist do it slightly off, but if you turn the dist, as if you were advancing it, ...itll go to 0 eventually, and be right, even though the dist is like bass ackwards with the #1 plug facing your firewall lol
Old May 7, 2003 | 02:00 AM
25THRSS's Avatar
Hmmm, thats interesting. Ive never had that happen, but I guess I'm just lucky. (knock on wood)
Old May 8, 2003 | 12:51 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Ok.
It doesn't matter if the dist gears are off cause if they are, you just pull the distributor back out, take a LONG screwdriver and turn the dist shaft by hand until the dist. sits in like it's supposed to.
Old May 8, 2003 | 12:56 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Well....
If #1 is facing anywhere near the firewall, you are way off. Either you have it 180 degrees off and it's facing toward the passenger's seat, or you have the distributor teeth off and it faces the drivers seat, either way, it's in wrong.
Bring the motor up to TDC#1. Put the distributor into the engine so that when fully seated the rotor is pointing to the sparkplug hole on Cyl. #1. Now put the cap on so that the rotor is facing BETWEEN #1 and #8 cylinders. It'll fire right up, THEN SET THE TIMING.This way your #1 cylinder plug wire should be right by your throttle brackets kinda, like it's supposed to be.
Old May 8, 2003 | 03:16 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Yeah, I don't think the EGR is your issue here. EGR is only added after the engine is up to temperature and when your MPH and RPMs are above a certain point. You would be suprised how good a V-8 can idle with only 4 cylinders firing right at idle.
Old May 9, 2003 | 12:38 AM
SlowMaro's Avatar
blah ok its all running fine now, i just toyed with it for a day or two and ran the brake booster in a diff place and it works good...
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
