Edelbrock Peformer Cam In 305 Tbi?
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
IS IT POSSIBLE TO THROW AN EDELBROCK FLAT TAPPET CAM WITH 194 INTAKE AND 214 EXHAUST INTO A STOCK 305 TBI MOTOR. I ALREADY HAVE THE CAM !!!!
Car: 89 FORMULA 350
Engine: 5.7 L98
I KNOW I CAN USE AN LT1 CAM,BUT WHAT HASSLES WOULD BE INVOLVED IN THROWING A FLAT TAPPET CAM INTO A ROLLER BLOCK.
Car: 2002 Z28
you have to change the lifters, timing chain, and pushrods, not sure if there is anything else that would need to be changed. But why go from roller to flat tappet.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
For $50 you can get a New Vortec cam at www.competitionproducts.com
The duration and LSA are very close to the LT1 cam. The lift isn't as high, but that just means you won't have to replace the stock springs on your heads.
Click here. It's the second to the last cam listed.
It's a direct swap.
It's a direct swap.
