Performance Chips?
Old Aug 7, 2003 | 07:47 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
Performance Chips?
Ok I have been told getting a custom burned chip for my specific vehicle is the best option on this. Question how much money, where is the best place or places to get it done and how much will this cost? Also how much actually change would I see from a chip on a 305TBI Formula. And O yea is the transgo shift kit the best shift kit to get for our cars? Thanks for any input
Old Aug 8, 2003 | 12:30 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Do other mods first like headers with a full 3" exhaust and gears and posi in the rear. You don't need to worry about one of those "custom" chips until you really start modding it.
Old Aug 9, 2003 | 09:13 PM
LedZep's Avatar
Ok thanx for the no answer answer. I am not looking to change the car alot just a few little things and I ask again what chip should I get if I am running a bone stock setup now. Links are helpful
Old Aug 10, 2003 | 01:43 AM
BronYrAur's Avatar
Engine: 305 TBI
Just because its not the answer you want to hear doesn't mean its not the most logical one. You really should get some other mods first. For the stuff the chip will do you can just advance your base ignition timing with a timing light a little and probably gain just as much if not more than with a chip. If you really want a chip though check out www.tbichips.com
Old Aug 10, 2003 | 10:38 AM
LedZep's Avatar
are those the best chips you can get, they are only 30.00 im jw is this what everyone buys who buys chips for TBI's ?
Old Aug 11, 2003 | 10:53 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
my custom chip is from Ed Wright at fastchip.com:
http://www.fastchip.com/
his customs are $300, but with lots of mods (cam, heads, injectors, etc) a custom chip is required.
-Rich-
Old Aug 12, 2003 | 01:28 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
He has a Formula. It should have posi already.
Old Aug 12, 2003 | 03:04 PM
BronYrAur's Avatar
Engine: 305 TBI
It's a 305 TBI Formula, unless it has rear discs and a smaller gear in the rear then its not posi.
Old Aug 12, 2003 | 03:17 PM
BADBIRD009's Avatar
I had a hypertech stage II chip in my 305 TBI with a K&n and a flowmaster, and low temp thermostat. the chip was the last thing i did to it and it by far made the biggest difference of all the other things i did to it.
Old Aug 12, 2003 | 03:50 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
i wish!
look at the sig ... my formula's a one-legger
for now
Old Aug 12, 2003 | 06:20 PM
LedZep's Avatar
Nah my bird is a open but I am switchin to a 3.27 posi soon hopefully.
Old Aug 12, 2003 | 06:23 PM
Engine: L03 305 TBI
aside from my black interior and manual trans, our cars could be twins!
i have a 3.42 posi ready to go in mine.
Old Aug 13, 2003 | 08:39 AM
twobirds's Avatar
Car: 1987 GTA 350
My mistake.
Old Aug 23, 2003 | 11:18 AM
LedZep's Avatar
how hard is it to switch a rear end out and how much money are we talking?
Old Aug 23, 2003 | 11:28 AM
BADBIRD009's Avatar
swapping a rearend is as easy as unbolting some bolts and brake lines and putting the new one in just like the old one came out. it can be done in a couple hours easily. you can probably look in a haynes manual to help you out.
check ebay they are always for sale on there. i have seen them for a few hundred bucks with discs and posi.
Old Aug 23, 2003 | 12:01 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the best chip is the one you make yourself.
for $150 you can get everything you need to burn your own chips. you can look in the diy-prom board, they have step by step insturctions for gathering the data and getting started. no one is going to be able to accuratly guess what you combo will do.
btw, we had a person on here with a stock l03 who LOST .2 in the 1/4 after a chip. i can tell you that with just small changes to my chip in my car, i have made big improvments, my MPH went up by almost 2mph in the 1/4. my et didn't really chage, but that is probably due to my crappy driving, but the MPH shows the HP gains from my own chip.
PurelyPMD
May 5, 2016 04:57 PM
85 Jimmy
Sep 30, 2015 07:56 AM
ramicio
Sep 28, 2015 01:18 PM
Deemax
Sep 12, 2015 06:53 PM
