Aircleaner ?s
Old Aug 10, 2003 | 02:57 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
Aircleaner ?s
In the Tech Articles section of this site, the first Utimate TBI article mentions a Mr. Gasket non-drop air cleaner. Is that an open element element, or is it a complete airbox?
Also, would it help anything to move the intake air temp. sensor to a cooler place, or would that just jack with the computer?
Finaly, whats the tallest aircleaner that K&N makes, 'cause if I get the drop airbox and put a truck lid on it, theres gonna be like 4" of clearance?
Thanx.
x
Old Aug 10, 2003 | 08:38 PM
25THRSS's Avatar
It's an open element and I would just put the iat back in the same place. I believe with the stock hood you can't go over 3 inches tall.
Old Aug 10, 2003 | 09:49 PM
SlowMaro's Avatar
i used a drop base air cleaner assembly....works good, also took off that stupid metal ring that the factory assembly sits on...
get a drop base 14 inch assembly, and a 3 inch tall k&n air cleaner.
get the xtreme air lid from K&N.
you can just lay the intake air sensor where ever , just make sure you hook it back up or you will get a ses light
Old Aug 10, 2003 | 09:51 PM
25THRSS's Avatar
You want to get a NON drop base air cleaner. Also, if you get a drop base and remove the gold ring you run the risk of contacting the coil which is a BIG nono. I would second ths x-stream filter top though just for the looks alone. Maybe a very slight gain too.
Old Aug 10, 2003 | 10:53 PM
SlowMaro's Avatar
i havent had a problem with my drop base...not sure why people say dont use it, ...i think it would pull more air in, more smoothly.
Old Aug 11, 2003 | 01:24 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Well, I'm making a custom cold air setup, so I need the closed airbox, not the open element. Does anyone make a non-drop airbox?
Old Aug 11, 2003 | 02:56 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i dont recall who, but yes someone makes a plastic "ram air" non drop plastic air box that would work... i see it in the back of car mags all the time. look in the back of HotRod or Car Craft....... its one of the smaller B&W ads...
as for the drop/non drop thing doesnt matter much, makes a huge diff anyway.
with a drop base, i measured about 4.20" of clearance between the sealling part of the drop base and the underside of the hood... take away a 1/2" for the stud, aircleaner nut and thetop and you can fit about 3.5" of air cleaner (i have a 3") and you should still have more then enough room for the engine to shift without it hitting the hood..
Old Aug 11, 2003 | 03:47 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Allright. Thank you. I've already decided agaisnt a new box and started cuttin up the stock one becuse I figured the drop wouldnt matter a whole lot either.
But, I still have a couple questions. First, would the metal, flexable dryer hose look cheep and retarded (it's all gonna be painted flat black to look stock)? Also, which would flow better, a 3" filter in the box, or one of the big, cone fliters on the end of the piping?
Old Aug 11, 2003 | 04:11 PM
SlowMaro's Avatar
you could get more flow from a cone type air filter, ...the stock replacement k&ns are so smallllllll
Old Aug 11, 2003 | 09:15 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Whats the min. diameter i should use for the inlet pipe? Everything I've seen has a 3" pipe, but I have a great idea if a 2" pipe will work. I shoudln't need too big of one, I mean, even after headers, Edelbrock intake, cai, ultimate TBI, chip, ignition stuff, pullys, chip, and timing, all of that, the pice of crap is gonna be good to push 200hp throgh the crank (but i still love her), right?
Old Aug 11, 2003 | 11:20 PM
SlowMaro's Avatar
thatll be more than 200 hp, and id use 3 if you could, smaller means less air flow...i mean your car is basically pulling and pushing air through straws as it is, lets try to pull in and push out as much air as possible.
Old Aug 11, 2003 | 11:29 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
More than 200? Are you serious?? I'm happy now!
Would running it from a 3" tube to a 2x6ish rectoval hurt it? if it was pretty smooth?
Old Aug 12, 2003 | 02:46 AM
SlowMaro's Avatar
circular is better, anything non circle isnt exactly the same width and height. but with all the mods you mentioned id say over 200.
Old Aug 12, 2003 | 10:09 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
what the heck makes you say that!?
if he has a L03 (im assuming he does), and the only mods mentioned in this thread are a air cleaner intake..
granted, there are several people who report a better azz dyno feel after doing the aircleaner mod, ( i cant say anything since i did several things to my car at the same time.. but it was faster when i was done)
but 200hp? not gonna happen.
my car dynoed at 152RWHP... counting that back to the crank, i make about 190hp. not too far from 200, but he isnt going to get the crabtacular L03 to pull 200hp by swapping the air cleaner.
if hes otherwise stock and hasnt done a tuneup recently, i would guess that hes making even less then the rated 170 at the crank
Old Aug 12, 2003 | 10:25 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Well, I said above that I'm puttin' on "headers, Edelbrock intake, cai, ultimate TBI, chip, ignition stuff, pullys, chip, and timing, all of that".. And she actualy jsut got a tune up last oil change, I put on some MSD 8.5mm wires, and a high performance cap and rotor (which I dont realy is better than normal), and its definitly back to the 170hp, or real close. I'm assumin its an L03, thats the only TBI engine they made right?
Anyway, does the stock flexible hose cause restriction? It's pretty big and just what I need to connect the 3" pipe w/ the box.
Old Aug 12, 2003 | 10:58 AM
25THRSS's Avatar
I can't remember exactly who it was, but there was some guy on here who actually did dyno his 305 tbi with the stock snorkel and with an open element and he gained 10 rwhp with the open element. Granted this is on a dyno with the hood open and air blowing on it, but it still made a pretty big difference.
Old Aug 12, 2003 | 04:37 PM
SlowMaro's Avatar
hey im no fool, i know JUST an open air element wont add 30 hp....i thought he said what will he have AFTER the intake, headers, yadda yadda....and when i said circular is better, i am assuming he ment he wanted to use some sort of pipe/tubing to extend the snorkle , put on a cone air filter, and ditch the air filter in the air cleaner assembly, ...that is what i gathered,
MotorCityMuscle
Carburetors
Sep 23, 2001 11:07 PM
Dirtybird355
Carburetors
Aug 26, 2001 03:20 PM
86 sports coupe
Aug 7, 2001 09:58 PM
TAdan
Jun 14, 2001 09:51 PM
MuchoCamaros
Feb 4, 2001 12:40 AM
