l98 cam
Old Aug 29, 2003 | 04:49 PM
thehagg
Guest
Posts: n/a
l98 cam
just wondering how a l98 cam would perform in a lo3. have done ultimate tbi mods,open air cleaner, headers and free flowing exhaust, and 3.42 posi rear
Old Aug 29, 2003 | 10:19 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
it would do ok. The 88/89 l98 cams have some pretty decent specs for stock stuff. IIRC the 90-92's where a little smaller. Just about anything made out of cast iron with some bumps on it will do better then the stock cam. If you have it already and you dont mind spending some time to put it in it would be worth it. If you dont have the cam then maybe a later model lt1 cam or similar efi friendly roller would be a better choice.
Old Aug 29, 2003 | 10:40 PM
25THRSS's Avatar
I believe it is a dyno proven 20 rwhp on an L03 with stock heads.
Old Aug 30, 2003 | 12:44 AM
dstefl's Avatar
Car: 91 RS
Engine: 305 TBI
Is there any dyno info on the late model lt-1 cam? 20 hp is not to shabby though.
Old Aug 31, 2003 | 12:10 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I think I might know where there's one you could buy.
Psst!!!Check my sig below.
Old Aug 31, 2003 | 11:41 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I picked up somewhere ~18 rwhp with a L98 cam and some other minor parts. The L98 cam actually idles quieter than the stock cam, which I think is due to the lobe seperation IMO. The car will need computer tuning to get it running well again after and cam swap. Just something to consider.
L98 cam and some tuning gained me .3 sec and 3 mph in 1/4. Basically the car lost some low end torque (below 3000 rpm) and gained HP above ~4000 rpm IIRC. Search for dyno graphs and LO3 that should fine my dyno before and after.
Old Sep 1, 2003 | 04:38 PM
Redline's Avatar
Car: 88 camaro SC
Engine: 305 t.oilet b.owl i.njection
Transmission: rebuilt 700r4
how would that cam you have for sale (96 lt1) work for a fairly stock 350?
Old Sep 1, 2003 | 05:41 PM
Car: 88 Camaro SC
Engine: SFI'd 350
it would work well for you. Like said above, youll want to consider burning a prom but you could probably get away without it, depending on how the car runs. Oh, youll definatly want to upgrade teh exaust at the very least. Lower ratio gearset would be nice as well but not absolutly necessary.
Old Sep 2, 2003 | 11:20 PM
prophecy xi's Avatar
can u even use the gen 2 sbc cams on a gen 1 small block?
Old Sep 3, 2003 | 05:49 AM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
The only thing to change may be the dowel pin - may need to be shorted... Of course your block/lifters/dist. gear must be "roller friendly"...
Jorlain
Oct 8, 2015 01:57 AM
scottmoyer
Sep 7, 2015 07:06 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
z28guy134
Sep 1, 2015 11:50 PM
