chip help!!
Old Sep 30, 2003 | 12:52 PM
AJB-283's Avatar
Car: 89 RS
Engine: 383
Axle/Gears: 9 bolt 2.77
chip help!!
I have an '89 rs t-tops with a 283(not a typo) tbi injected, crane cam hydraulic cam. 114 degrees of lobe seperation, 266, 272 duration.this is carb cam. long story on how that all ended up. compression is at 9.3 to 1. headers with 3" cat back(not much to the cat either). 3.42 gears. tranny is custom built vette tranny th700r4. torque convertor is a saturday night special. any ideas on where i can find a good chip that will work with this combination?
Old Sep 30, 2003 | 01:01 PM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
tbichips.com
Old Sep 30, 2003 | 01:08 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
burn your own, its the only way you are going to get an accurate tune with that odd ball of a combo. especialy since that is a fairly healthy cam for a 283. luckily it is a 114lsa, if it was a 108 you would really be hard pressed to tune it.
Old Sep 30, 2003 | 01:14 PM
Car: 91 RS
Engine: LO3
yes, dewey is right, he is alot of of the time. i figured you meant where could you buy one. but yes any time you can burn your own go for it, thats how these guys are getting their killer track times and gas mileage.
Old Sep 30, 2003 | 01:23 PM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
yes and if you don't have the stuff... pm brharris he can burn you a custom one if you tell him what you have...
Old Sep 30, 2003 | 01:35 PM
Car: 91 RS
Engine: LO3
exactly
Old Sep 30, 2003 | 01:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by nick harmon
exactly
And how 'exactly' will the result be?
RBob.
Old Sep 30, 2003 | 02:05 PM
Car: 91 RS
Engine: LO3
gotta be better than stock. ive heard no complaints, only praise.
and with that, im out
Old Sep 30, 2003 | 02:36 PM
z28wiz's Avatar
jet chips
Old Sep 30, 2003 | 06:43 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
The stock chip would run better than a jet chip or any "off the shelf" chip for that matter.
Old Oct 1, 2003 | 10:20 AM
AJB-283's Avatar
Car: 89 RS
Engine: 383
who is the person that can burn a chip? any help that i can get is greatly needed. i tried jet chips, they referred me to fast chips and they toldme to put a carb on it. don't want carb. i want to keep this thing fuel injected!!
Old Oct 1, 2003 | 10:34 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If i were you I would research how to do it and tackle it yourself. I too was turned off by the idea and it seemed so far fetched. One day I actually watched someone do it and low and behold it is pretty simple. Like anything with cars, it takes time to learn but will pay off in the future.
Old Oct 1, 2003 | 10:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The only person that can burn the proper chip for you is yourself. It is well worth the effort to purchase the tools and learn it. The only warning I have is that it is addictive.
See the top post of the DIY PROM board for an intro.
RBob.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
