vortecs + rpm air gap + egr = headaches!!!!
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
i want to run vortec heads on my l03.
i want to run an rpm air gap intake
i must keep my egr functional.
ha ha ha .... those 3 roads don't intersect.
i know i can get the exhaust output for the egr from one of the air tubes on my headers.
the challenge is ... how do i get the exhaust gasses into the egr valve, then into the intake?
i've often wondered why you couldn't simply drill a hole into the plenum and plumb the output of a remote egr valve in.
if that were the case, it'd open a lot of options like performer rpm, rpm air gap or even stealth ram or mini ram.
can anyone help?
can anyone help?
Car: 89 Shortbox
Engine: 350 Vortec
First off there is nothing good about EGR, it sucks. I would think though, that you could bore into the intake and make it mate up to the EGR valve, with the use off a machine shop, or a dremel. but more than likely you'll wreck the intake.
Engine: L03 305 TBI
Engine: L03 305 TBI
Originally posted by vjo90RS8
I dont even think that the Vortec Air Gap intake has EGR. So it would be pretty much impossible
v6 3rd gens, i believe, used a remote egr (one that didn't mount directly to the intake). i'm wondering if it'd be possible to adapt one of those or something like them to fit egr to a non-egr induction system.
Car: A Camaro
Engine: Weak
Transmission: Weaker
I remember reading that Corvettes ran an external EGR and some late model trucks, run a search on it for "external EGR" and something should come up. It's definately do-able.
Good Luck
Tony
Good Luck
Tony
Car: 2002 Z28
the external EGR on the vortec engines takes exhaust gases from the exhaust manifolds and feeds it into the intake manifold via an external hose. But the intake still has an EGR valve to regulate when and when not to feed the engine with exhaust. You could just tap into the RPM intake and draw exhaust gases from the AIR tubes on your headers but unless you have a valve youll have constant exhaust entering your engine which would hurt performance i believe. I would just go with an intake that has EGR because performance intakes and EGR just done go together. Worst case you go with a GMPP TBI or carb vortec intake with EGR. Not sure if Edelbrock makes a vortec intake with EGR and if they do it is probably just a Performer model.
Engine: L03 305 TBI
getting the exhaust gasses from the air tubes makes total sense.
you're right about needing an actual valve. iit's closed at idle and wot, so you get no exhaust gas in the mixture at those times.
i seem to remember 2.8 v6 fbodies having an external egr valve. i think fords do, too. if that's the case, all you'd have to do is plumb the output of the valve into the intake, wouldn't you?
aside from fitment issues, are there differences in how and/or where different egr valves open and close?
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
If you need to pass a "visual", why don't you mill a pad on the RPM-Air gap, drill and tap bolt holes, slap on an EGR, and put a vacuum line to it. The thing won't actually be DOING anything, but not IM pud will ever know that.
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
-Rippin
Engine: LT1, L400
Originally posted by Rippin92RS
Genius. Will he still pass the sniffer though?
The car can be "tuned" to pass the sniffer part, w/o an EGR. I used to get my CFI and my moms 86 TPI to pass the sniffer in Mass w/no EGR. Here car even did it w/no Cat -though barely.
Engine: L03 305 TBI
Are you busting my ***** or are you being serious?
regardless, i'm going to keep the egr functional.
i was in a speed shop this weekend looking at a performer with egr. i just can't see why you couldn't use a vette remote egr and plumb a line into the plenum. it seems so simple, but the fact that it doesn't appear to be commonly done concerns me. if it was that easy, it seems like more people would be doing it.
Car: check
Engine: check
Transmission: check
Originally posted by seanof30306
here they check the egr for function.
As for adding it, the pre-90 v6 f-body's use a vacuum EGR that sits on a pedestal. The pedestal is mounted on the pass side exhaust manifold. There is a metal tube that goes from the EGR valve to the plenum behind the TB. ('90-'92 use a digital EGR).
These parts should provide the material you need.
To plumb it to the Performer air Gap just need to take in to account the dual plane-ness of the manifold. The best way would be to come in from the bottom, centered on the divider. This would give the cleanest look and an even distribution of the EGR within the manifold.
Could also come in from behind the plenum with either a hole on each side, or a single hole centered on the divider. It may end up with more EGR toward the rear cylinders, but I believe that most OEM manifolds also bring in the EGR from the back of the plenum(s).
RBob.
Engine: L03 305 TBI
Originally posted by RBob
Last question first. Probably not done as it is easier to just ditch the EGR.
RBob.
RBob.
you know, i'm going to have to go back and look at the performer again.
it looked to me like the egr cam into the intake at the bottom of the passenger side of the plenum. if that's the case, then the driver's side of the plenum would get no exhaust gas. that can't be right, can it?
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Dialed_In
Aug 20, 2015 01:45 PM
