In the 13's, post your combo here
Old Nov 30, 2003 | 11:08 AM
JPrevost's Avatar
Car: 91 Red Sled
91 camaro hardtop
Full street trim with more suspension mods for handling than launching.
330ho crate motor, edelbrock RPM intake, holley adaptor plate, holley 670 with 28psi fuel pressure (custom spring), walbro 255 fuel pump, SLP shift kit in 4L60, 12" 2800 stall lockup TC, 3.73 richmonds, take-off torsen, SLP tri-y headers, Borla cat-back, custom eeprom, open element, removed a/c, harwood 2.5" glass cowl hood, and stock size high performance all seasons. Everything else is stock from the steering wheel to the radiator and driveshaft. Most stock parts have 180k miles. Manages a 13.65 at 103 in typical weather at 800'. That's with picking up knock 5 seconds into a pass resulting in 10 degrees of timing removed for the rest of the run . All in all, great car, love the way it drives but if you want better city gas milage, go with a lower stall converter. 2200rpm should be plenty to run similar times even with the 4-1 headers.
Old Dec 1, 2003 | 10:36 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: In the 13's, post your combo here
Originally posted by JPrevost
91 camaro hardtop
330ho crate motor,
84 Firebird.
13.6x, 99.99 (circa '95/96)
Converted to Cross Fire.
355, CompCam 270, 9.5:1, AL vette heads.
2" throttle butterflies, early BBC injectors, opened up the port pockets, and cut the runner roofs back some.
Edelbrock TES, Crane Ignition, Black Magic rad fan, 3 row brass radiator,
Big front sway bar, Art Morrison C-O conversion, Reese Rear Bar suspension, 700R4 non-lock up, partcially gutted, glass hood, BFG tires, Bassett rims, 1227747 ecm.
Old Dec 1, 2003 | 10:45 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
any chance you guys could post your cam specs?
Old Dec 1, 2003 | 02:51 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
In the sig
Like Grumpy, Mine's Cross-fire too.
Old Dec 1, 2003 | 04:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
272d advertised.
224d at .050
.480 lift
110 LSA
installed straight up.
1.52 roller tipped rockers
Old Dec 1, 2003 | 04:43 PM
Dewey316's Avatar
Car: 1990 Camaro RS
LSA - 110
you are my new hero, how did you tune that
Old Dec 1, 2003 | 04:45 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: In the sig
13.25 at 105.
Congrats.
Old Dec 2, 2003 | 02:30 AM
JPrevost's Avatar
Car: 91 Red Sled
Stock crate motor cam. Specs are 212/222 @.05 .435/.460 lift with 114 ls. It's so mild that she'll idle rock solid at 600 when warm. Any lower and oil pressure gets too low for my comfort and tip in becomes difficult.
Full street trim when I ran those times and I have GOT to fix my slipping transmission. I think it might account for the knock I'm getting in 3rd gears shift, only happens under WOT. Engine revs up scary high if you hold 2nd gear too long.
Old Dec 3, 2003 | 09:04 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
Yea my tranny would hold second too long and a certain rod bearing did'nt like it.
Old Dec 11, 2003 | 02:49 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
on my s10 i run the hott cam w/stock tbi need a new chip and intake and that holley 670cfm..
Old Dec 12, 2003 | 10:19 PM
JPrevost's Avatar
Car: 91 Red Sled
I know a guy running low 13's but that was with a 125hp shot on an Lo3 with a great suspension setup.
Old Dec 14, 2003 | 11:59 PM
Racer3313's Avatar
Car: 1991 Camaro RS
Engine: 305 LO3
Transmission: TH350
Axle/Gears: Ford 9" 3.70 gears
Motor is stock below the Edelbrock Performer intake with 95k. The TBI unit is stock with Turbo City mods. Extensive supension modifications including Hotchis RTAs and panhard rod, Spohn adjustable tork arm, Eibach drag launch springs, Lakewood drag struts and shocks with and airbag in right rear spring.
MD
Old Dec 15, 2003 | 08:38 PM
ben73's Avatar
Another crossfire here, 84 Vette.. 13.73@100.1mph
Untouched stock bottom end
Port matched and de-EGRed manifold
85 Vette fuel pump
15 psi FP
cold air mod
' 89 '113 L98 heads
208/215 @ .050 .459/.480 cam
Comp cams 1.6:1 roller tip rockers
Dual 2.5" exhaust with X-Pipe no cat
Tri-Y headers
Stock ECM
Stock injectors
Stock TB's
Transgo shift kit
This engine wiped a cam lobe a few weeks ago, so I've just pulled it out and stripped it.
The rebuild will be a roller cammed 383 with AFR195's and and X-Ram with 2" TB's and 90Lb injectors, controlled by a '7747. Got the block back from the machine shop today ;-)
Hoping it will run a second quicker than the above setup!
Ben.
Hotrodboba400
Dec 10, 2019 07:07 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
mrdevontay
Sep 2, 2015 08:04 PM
z28guy134
Sep 1, 2015 11:50 PM
