L05
Old Feb 24, 2004 | 07:25 PM
Teal91rs's Avatar
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
L05
Alright im kinda half and half on descideing if i have a l05 or not the guy said its 5.7 and a 350 and i havent had time ot take of the alt to look at the casting number but i was wondering what do you think a l05 would run in a stock camaro?
Old Feb 24, 2004 | 07:32 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Probably mid to low 15's. I think you can look on the back of the block and there should be a "5.7" on it if its a 350.
Old Feb 24, 2004 | 09:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree. The LO5 sadly is not much better than the LO3 and should run a few ticks quicker in stock form. However modding it will take you a lot farther than its 305 cousin.
Old Feb 24, 2004 | 10:08 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Yeah the L05 is definetly not the best motor in the world. I would think that a stock L05 would probably run in the mid 15's with an in our cars depending on gearing and which tranny you have. My car ran like a 15.1 with the an L05 and 3.08 gears when I first put it in, but the motor came out of a modded truck and I dont know if the guy did anything to the heads or if he swapped cams.The L05 has 40 more hp and like 40 more foot pounds of torque than the L03 and it will defnetly respon better to any mods you do to it so I think its a great base to start with.
Old Mar 2, 2004 | 09:57 PM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
And the L05 runs just as long as the L03, forever. (I suppose the fact that the cam barely moves the valves off their seats has something to do with it.)
Old Mar 2, 2004 | 10:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
With jsut the L05 and the stock exaust and such its going to be a pig. The shortblock is ok, though. With some small chamber heads like a worked over set of 081's or 416's, decent cam, exaust, TC and gears it would probably do ok.
Old Mar 2, 2004 | 10:03 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Low power output, low RPM band, and minimal amount of parts make the TBI motor last long. It is not uncommon to get 200K with ease.
Old Mar 3, 2004 | 09:12 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
Your not kidding Shiffty my friend just hit the 275,000 mark in his 88 Firebird L03. Who says that GM motors don't last???
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
Brent
Dec 5, 2003 11:28 AM
kevm14
Apr 23, 2003 12:50 AM
dammit32
Feb 26, 2003 09:35 PM
