305 to 350 help
Car: '89 RS
Engine: 383 in progress
Transmission: TH 700-R4
305 to 350 help
I currently have a 305 TBI (L03) and want to swap in a 350. I was told it would be easiest to put in another TBI so i foundThis . What modifications would i need to make for this swap??
Car: 1990 Firebird
Engine: LS3
been there done that
as long as that engine has all the correct sensors theres not any real mods nessacary (I just did that swap and it wasn't hard at all, unfortunaltely though my engine has 130some thousand miles on it from a bone yard). anyway I found the swap fairly easy (just time consuming).
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would not waste your money on that particular motor. It has junk heads and cam. I would look into a used L98 shortblock or LO5 shortblock. It is relatively easy to swap in a 350 TBI as long as you have your car prepped for it. By prepped I mean full exhaust, upgraded fuel system, and the ability to get or burn a new chip.
Car: 1991 Chevy Camaro
Engine: 305 TBI
Darn, I forgot! A better fuel pump. Most people get the Walbro 190 lph fuel pump. I can't remember where to buy it, though.
Car: '90 RS
Engine: 377 LSX
Originally posted by meeklay812
What do i need for an upgraded fuel system???
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
to add onto his question could i buy a prom from TBIchips.com for a camaro with a 350 tbi (L05, im assuming) there were thirdgens from the factory w/ 350 tbi right? i think it would be easier to just buy a performance prom for that. also how much of a gain/ difference should the swap make can it get the car into the 14s w/ minor bolt ons ie. the mods that i have now? meaning if i had an open element, 3" catback, and a posi w/ 373s in an auto are high 14s possible? just curious
with your 350 in there, the chip dialed in and the mods you already listed I'd think high 14's are reasonable. Oh, and no camaro came from the factory with a 350 TBI. As far as i know that was a caprice engine. I forgot what other car used the engine also but it wasn't a camaro.
Car: '90 RS
Engine: 377 LSX
305 and 350 motors could be found in the caprices. They were roller motors. You could also get 305 and 350 TBI eigines in pick up trucks but they were non-roller motors. Whatever TBI motor you come across you will want to add at least a cam to it while it is out of the car. There really isn't point in swapping motors that perfrm marginaly better than your 305.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I totally agree with Shifty above. If you swap in a 350 setup and are running high 14s as suggested above; that is sad. I wouldn't go through all that hassle to run high 14's with a weak-*** 350 build. You could do headers, full exhaust and gears/posi and hit high 14's easy in an LO3.
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
http://www.autoperformanceengineering.com/
sells the walbo 190 pump for like 83 dollers or somrthing like that. and its perfect for 350 motors and the stock pressure regulator works fine with it.
