Knocking?
Car: 1992 Chevrolet Camaro RS
Engine: 305 TBI
Knocking?
Hello I seem to have a problem I have noticed that in the past few days to me it seems that my valves are knocking the make a very horrible rattling sound when I am accelerating from a stop. It is a 1992 Camaro RS with thw LO3. What should I do?
William
William
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well knock is not your valves ratteling. I would start by checking your timing. If you are to advanced you can get some knock. Also a failing EGR or incomplete ignition can cause knock. What are your water temps?
Not always, but sometimes a rattling sound can be a leak at the exhaust manifold. They don't have gaskets, so one loose or missing bolt can make a tick tick tick sound, if that's what you're hearing.
Car: '90 RS
Engine: 377 LSX
Originally posted by Dennis91RS
take a peek at the oil pressure sounds like a spun rod bearing to me
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Sure its not injector noise either? A lot of people mistake the ticking that our injectors make to be something bad.
Engine: 305 TBI
When I have my hood open and my car is idiling and I stand over it I do not hear a ticking noise or even knock, could it be like in the drivetrain or?
Thanks Again,
William
Thanks Again,
William
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
boy...... thatsounds like a rod knock to me. 305s around here, i know of 3 have done the same thing
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I am having the same problem, but it's only at temps above N.O.T.(normal operating temp.)
I have retarded base timing to -2* before I retarded it, I had it at +1* to +2* and was getting almost 100 ping counts just accelerating 0-40 since, I have retarded the timing down to the -2* and it is fine until the motor is above normal temps. I know the difference between ping and rod/lifter/rocker/etc. knocking.
I have ran SeaFoam through it thinking that might help some carbon in the cylinders, but that doesn't seem to do anything, besided make smoke.
I modified the exhaust, and now the EGR no longer works. I don't know if I need more back pressure, or what, but it will throw a code 95% of the time I drive over 55mph.
I'd like to get this figured out, because I liked the 2nd gear scratches I was getting with the timing advanced 2*.
This is a completely stock motor besides the ehxhaust and open element. I can't believe the car is running lean, but the way my gas is used, I'm thinking it's running rich.
As soon as I find time, I'm going to run it on the laptop and see what sort of readings I am getting.
Anyone have any thoughts, or need any more info as to the situation? I'm sure this is pretty much the same problem that BADASS92 is having.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
other then telling you to check your timing (correctly with the plug disconnected, it should be 0*) theres not much we can tell you online.
i suggest you take it to someone who can look it over.. if it is a audible knock, you could severely damage the motor if you continue driving it.
Car: 1991 Camaro RS
Engine: 4 bbl 305
8 times out of 10 an engine will not knock at idle with a spun bearing it depends on how bad its spun. alls the knock is when its spun is the piston hittin the bottom of the head
a car with a spun bearing will start to knock at about 1500-2000 and get worse and louder as more rpms are given
when the old 305 in my car spun a bear it did not knock at idle it did exactly what i described
when the 307 in my oldsmobile spun a bearing it did the exact same thing.Then i took the motor out and dropped in a nice little 350
and again i had a 2.8 V6 Camaro that spun a bearing and it did the exact
KEEP IN MIND a car with a spun bearing will still hold oil pressure usually
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
