Track Times!!
Old Jun 6, 2004 | 01:58 PM
firebirdvert305's Avatar
Car: 1992 Firebird Convertible S/E 1 of 1263
Engine: 5.0 liter 305ci LO3
Transmission: 700R4 Automatic
Track Times!!
Hey guys i just went to bithilo last nite and ran my car for the 1st time and all i can really say is im really dissapointed MY car has a rebuilt transmission with shift kit...i DID A FULL TUNE UP about a month ago new cap, rotor, spark plugs, wires, fuel filter, 02 sensor!! heres what i got outta my 305 LO3 R THESE THINGS REALLY THIS SLOW???
1st run:
R/T.. .674
60'.... 2.416
330.... 7.020
1/8.... 10.820
mph.... 64.66
1000.... 14.111
1/4..... 16.901
mph.... 80.83
2nd run: (redlighted)
R/t.. .486
60'... 2.598
330... 7.260
1/8.... 11.038
mph....65.34
1000.... 14.314
1/4..... 17.097
mph.... 81.13
PS. lemme remind you guys its a convertible LO3 305...I GOT virtually no tire spin it was 2 awesome launches with great RT's...My mods are open element, shift kit, and flowmaster muffler 80's series and the car is in great tune.(o yea i got 2:73's too)....ARE THESE TIMES RIGHT??? HELP PLEASE
Old Jun 6, 2004 | 02:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Even with the added weight of a convertable you should be pulling better times than that. You should be able to at least pull off a 16 flat in stock trim. Have you done the little things like bumping the timing up a bit along with the ultimate TBI mods?
Old Jun 6, 2004 | 04:03 PM
nope
shifty timing is set at 0 degrees same as stock...only thing i really did was add a open element, remove the cat, add a flowmaster muffler and thats about it...im running BFGoodrich radial TA's...i dunno y the car is so slow espically with a new tune up and rebuilt tranny...mileage on the car is 142k and 80% of it is highway mileage...y so slow??
Old Jun 6, 2004 | 08:35 PM
25THRSS's Avatar
Try shifting higher. I gained .5 and almost 4 mph shifting at 5000 instead of letting the car shift at 4400. Also, your 60 foots are horrible. 2.4/2.5 is no where near awesome. I still think a 16 flat is a bit optimistic, but you should atleast be able to cut that down to a mid 16. Another trick is to leave your ac on in the staging lanes which turns your fan on and helps cool the engine. Ofcourse you need to turn it off when you are about to go, lol. Good luck
Old Jun 6, 2004 | 09:06 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
i dunno that might be all it can turn with the convertable
my RS bone stock turned 16.6-16.7 all night long
Old Jun 6, 2004 | 09:28 PM
my
60foots have nothing to do with traction cuz i launched it perfect no tire spin at all...none what so ever...as well as leaving my AC on..i have a manual fan switch on the car so it was cool all the time. ..1st time i shifted at about 4700 rpms....with the 2:73's im virtually done with the 1/4 in 2nd gear (end of 2nd)...i might have to try and shift at 5k next time..
Old Jun 6, 2004 | 09:33 PM
i dunno man
Im selling the convertible its so gorgeous but i think im gonna let it go. My dream car is an LS1 WS6 or SS im in the market for one...still dosent explain y i ran a 16.9 with the vert with good tune and brand new tranny
Old Jun 7, 2004 | 02:00 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
You're short shifting it at 4700. Bring it to 5000 definitely I think. Advance the timinig a few degrees at the distributor. And did I read that right that you had the A/C on the whole time?? A/C will rob lots of power from you, if you want to keep the engine cooler run the heater not the a/c. Also, you didn't get any tire spin but you may have bogged it off the line. Brake torque it up to higher rpm and launch at the point where its about to spin the tires but doesn't, practice.
Convertibles can still run fast. I have a catback, open element, and 3.42's and I'm hoping to be running at least very low 15's maybe high 14's, we'll see. Keep working at it though, these verts are great looking cars too!
Old Jun 7, 2004 | 03:43 AM
S!MON's Avatar
Car: '87 Camaro Z28
Engine: fully loaded 350
Transmission: T5-World Class
when I had my car new, I ran a horrible 17.5!!
after that I made a tune up (accel wires, all filters, oil change, new spark plugs...and an open element)
and guess what:
16.1!!!
never get that time again, since then I run consist 16.2..with a manual.
I can't await to do my lt1 cam swap with full exhaust...all parts are bought. now I have to ship them from my aunt in the us to germany $$$ urgh
greetings
S!MON
Old Jun 7, 2004 | 06:46 AM
AC
was not on...i was just implying i have a manual fan switch so the engine wasnt hot. No doubt bout it the verts are the best looking 3rd gens around just sometimes i wish i had a L98 under my hood
Old Jun 7, 2004 | 08:14 AM
hey
guys got a check engine light before i ran the car...code 32 EGR i believe would this code make horrible track times? Car feels kinda weird at idle like stumbling, hesitating....Kinda get me a lil mad after i did a full tune up to the car. Where is the EGR even located in the car...should i buy a new one or just clean this one out? Any tips or tricks? Could this problem really effect my track times this greatly?
Old Jun 7, 2004 | 10:14 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: hey
Chances are it is shot and needs to be replaced. If it had less mileage on it I would suggest cleaning it out. If your EGR is haning open than you could have found your problem.
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
