Finished Performer TBI install...now help me diagnose...
Old Jun 23, 2004 | 12:21 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Well, after taking about a month, I finally got the RS back together and drove it today. First off, the car has 69K on it, and this is what I have done:
-Rebuilt the TBI/Injectors with a GPSorenson kit including all gaskets and cleaned the hell out of it...this thing looks brand new inside and out.
-Installed Jegs TBI Injector Spacer
-Installed Edelbrock Performer TBI
-Installed New GM EGR Valve
I spent hours doing this to ensure I did it all by the book the first time.
Before I did this, the car had MSD Blaster Coil, Cap, Rotor, 8.5 Wires, ACDelco Rapidfire plugs, Catco 3" Cat, Flowmaster 3" Cat-Back.
PROBLEM: Got the car running, drove it, and now it has a massive hesitation at low RPM! It will really bog down when I start from a stop, and it will continue to bog down at the beginning of all the gears. It will bog for a second or so and then slowly accelerate, once I'm in the upper RPMs it feels OK and seems to stop bogging. On inclines or hills, I can't even use 5th gear at all because it has absolutely no power. So I'm wondering what is causing this...could I have changed timing by accident messing with the distributor reinstallation? Is it my IAC, my TPS, or something I didn't do with the throttle cables?? Please help!
Old Jun 23, 2004 | 12:24 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you re-set the timing? What did you set it at? Sounds like a timing problem.
Old Jun 23, 2004 | 12:39 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
I don't have a timing light, and I'm relatively new to doing my own work on my cars, so I am going to have to take it down the street to a friend to get the timing checked. I'm hoping its just timing...I spent too much time on this to have to tear it all apart again. It sounds good at idle, nice deep, steady rumble, but its just when I start to move, it has no power...still think its timing?
Old Jun 23, 2004 | 12:46 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yes it is your timing. You have to re-set the timing any time you remove the distributor no matter how close you think you have it. Remember to unplug the EST as you set it.
Old Jun 23, 2004 | 03:01 AM
CanCritterRW's Avatar
Car: 91 gmc 4x4 tbi :O)
est?
Old Jun 23, 2004 | 09:52 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Thanks Shifty, I'll take it down to my friend's shop and get it done. I'll let you know if it was the timing.
Old Jun 23, 2004 | 10:07 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by CanCritterRW
est?
You have to unplug the est to set the base timing so that the ecm does not interfere. It is a brown wire right over the passenger side strut mount.
Old Jun 23, 2004 | 03:56 PM
ah....thnx kindly
Old Jun 23, 2004 | 04:56 PM
BigBadJap's Avatar
Car: 1989 GMC Jimmy Fullsize
Engine: 5.7L TBI (LO5)
Does the problem happen only when the engine hits normal operating temp and not when cold?
Maybe try putting a tee in the line to the egr valve (block it so the egr doesn't work) and then take it for a test drive, and see if it does it. Mine had a weird stumble at low rpm, I blocked the EGR and it went away.
It's a five minute test, and it's free.
Old Jun 23, 2004 | 06:21 PM
25THRSS's Avatar
Just so you know timing lights are cheap and good to have. I think I bought my Mac tools light off ebay for like $8, lol.
Old Jun 23, 2004 | 07:04 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If he did not set the timing after he put the distributor back in that is his problem. Timing, final answer.
Old Jun 24, 2004 | 02:26 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
I can't get the Camaro in the shop until Monday, so I'll let you guys know what plays out. I'm just hoping shifty is right and its just off timing.
Old Jun 26, 2004 | 09:59 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
Shifty is correct.
Old Jun 28, 2004 | 09:54 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
OK, I got the car in the shop and they said my timing was set at 12*!!! No wonder I had no power! Anyway, they set it back to factory spec 0* and for most part the hesitation is gone. I still feel a tiny bit of something in the low RPMs though...I had them install a new fuel filter while they were at it. I bought a new GP Sorenson TPS at Advance today and will be putting it on tomorrow to see if there is any difference. Any more advice on how to make my L03 run better than new?
Old Jun 28, 2004 | 10:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I would have them set the timing to 4* advance. 0* is the stock setting but a little base advance can give a little more throttle repsonse and a few ponies.
MustangBeater20
Oct 29, 2022 09:20 PM
Hawk312
Aug 22, 2017 08:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
Randomtask2
Aug 13, 2015 01:57 AM
armybyrd
Aug 10, 2015 09:23 PM
