Aug 5, 2004 | 11:14 PM
Ok, when I first start my car, it idles high, aboout 17-1800. after about 5 minutes it drops to about 1000 and stays there. What are some of the things that cause this?
Reply 0
Aug 5, 2004 | 11:19 PM
Its normal to idle a little higher until it warms up. 1,000 rpm is still a little high, but factory tachs are known to be crap, so make sure your tach is correct first.
Reply 0
Aug 5, 2004 | 11:25 PM
Ok, just saw your post about the aftermarket tach..... Anyways, check your IAC to begin with. Your throttle cable could be sticking a little as well, or the blades are not closing all the way. Sea Foam works wonders also, it will help clean out carbon build up.
Reply 0
Aug 5, 2004 | 11:31 PM
did the sea foam thing, love that stuff.
I know it is supposed to be little higher, but this no matter if it is alrady warm or not.
Reply 0
Aug 6, 2004 | 12:51 AM
1000 at idle when warm is kinda high, mine idles at 500. Did you mess with the throttle stop screw on the TB.
Reply 0
Aug 6, 2004 | 10:54 AM
I have not touched a thing.
Reply 0
Aug 6, 2004 | 11:42 AM
Have you checked your IAC?
Iggy, do you have a cardomain sight or something, I think I've seen your car around.
Reply 0
Aug 6, 2004 | 12:17 PM
Formula4Speed
No I don't but heres a pic. Where in DE are ya?
Sorry to be off topic.
Have you checked all your vacum hoses.
Reply 0
Aug 6, 2004 | 01:27 PM
I'm from Newark, maybe 10 minutes from hockession if you ever want to get together with some f-body people check out www.firststatefbody.com
On a technical note could the MAP cause his problem?
Reply 0
Aug 6, 2004 | 06:25 PM
My 305 idles pretty high at cold start up. Eventually it comes down to 500-600 range when the engine warms. To be honest the car is still pretty new to me so I don't know what it should be.
Reply 0
Aug 6, 2004 | 10:17 PM
Quote:
Where is the IAC?
Reply 0
Aug 6, 2004 | 10:23 PM
Passenger side of your TBI unit, it's screwed into the base. It's got a plug into it and is basically a pintle that is opened and closed to let more or less air into the engine without cracking the throttle blades open.
Reply 0
Aug 6, 2004 | 11:52 PM
Uhhh... dumb question.
Sea Foam? What dat?
Reply 0
Aug 6, 2004 | 11:59 PM
Sea Foam does wonders. It is a fuel system cleaner, as well as a carbon cleaner, which is what I like to use it for. Basically it helps clean vavles and exhaust ports of carbon buildup and the like. It can also be used in the crankcase, though I'm not a big fan of using any "cleaners" in my oil, but that is just me.
Reply 0
Aug 7, 2004 | 10:15 AM
Damn! I am lazy. It's amazing what a Google search will do:
SeaFoam Articel
So how's the weather south of Atlanta? Thanks for the scoop. Now I just have to locate where to buy this stuff on the Bay Area peninsula.
Reply 0
Subscribe
