throttle adjusment on the throttle body
Old Aug 11, 2004 | 08:54 PM
Ann.racer92's Avatar
Car: 92 Camaro Heritage RS
Engine: 5.0
how do you adjust the throttle cabe to tighten it up? i put a brick on my go petel and it only opens it like 9/10ths maybe of open throttle.also how about the tv cabe, should that lil button be level with the casing of it or does it require very hard pushing to get it to go right.
also should your fuel injectors pulse instead of throwing a steady stream and should they be throwing larger particles of fuel or should it be a even cone of mist?
Old Aug 11, 2004 | 09:05 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your fuel will pulse and it should be a fine mist with an occational small (and I mean small) droplet.
Old Aug 11, 2004 | 09:10 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Work the throttle with your hand from inside the engine bay and look at the injectors. When you give it a lil' gas the pulsing fuel should appear to be a perfect cone. If it still looks choppy, try some fuel system cleaner. You'd be supprised how well that works...
Bruce (90RS305)
Old Aug 11, 2004 | 09:45 PM
Engine: 5.0
no reply on how to adjust the throttle cable? should it only open that much? and will the ecm read that as WOT as it reads its lowest point as idle? i would think this would all make a big diff in 1/4 mile performance
Old Aug 11, 2004 | 11:06 PM
90RS305's Avatar
At WOT the butterfly should be on about an 75-80* angle IIRC. Check the springs and sutch under the gas pedal...
Old Aug 12, 2004 | 11:08 AM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
As has been mentioned, make sure it's nothing simple like something (carpet, floormat, etc.) keeping the pedal from going further. If that's not it, I think you're left with modifying bracketry to get the throttles open further....?
You could take a look via a scanner to see if you're getting 100% TPS in the ECM. I don't think there's a max throttle learn type of algorithm in the ECM. But, it might be I just haven't run across it, yet.
If the throttle opening (or lack thereof) is not allowing MAP to go to whatever ambient atmospheric pressure is, you are correct there's going to be a hit on performance. Again, with a scanner, you should be able to compare BARO and MAP to make sure the throttle isn't obstructing flow.
Old Aug 12, 2004 | 09:50 PM
Engine: 5.0
ehhh. this is going to be more difficult then i imagined.. i really really need to get a laptop
Old Aug 13, 2004 | 03:12 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You cant adjust a stock throttle cable. If you use an aftermarket one then you have adjustability but the stock one is non-adjustable. Almost all the way open will be good enough. You could check to see for obstructions behind the gas pedal but thats about it.
EDIT: Dont mess with the stock cable bracket. Your transmission will hate you for it if you bend it all up. Take it from me, the geometry for the TV cable is critical for proper tranmission function. Dont know why they didnt use vacuum like the older units, that tv cable sucks...
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
