Testing pump on a 90 Formula????
Old Sep 11, 2004 | 10:07 AM
Mr.Crackhead's Avatar
Car: 1990 Formula
Engine: 355
How do I test a pump on a 90 Formula?? can't seem to find a test plug, I have a plug close to the relay , but it has a blue wire coming from it. Any thoughts and help is greatly appreciated.
Old Sep 11, 2004 | 10:08 AM
Car: 1990 Formula
Engine: 355
Car had acted up one or two times, parked it last night and got into it this morning and teh fuel pump will not come on. Checked and changed relay, Fuse by the battery is good, and help please.
Old Sep 11, 2004 | 11:06 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It should be a red wire coming out of pin "C" of the fuel pump relay. Since you have a blue wire, check to see if it goes to the fuel pump relay.
Old Sep 11, 2004 | 11:30 AM
Car: 1990 Formula
Engine: 355
This blue wire is running back into the car, might be hood light or something. So can I just tap the red wire or C and get it to test it?
Thx Trickster.
Old Sep 11, 2004 | 01:06 PM
njspder's Avatar
Car: 1976 Camaro LT
Transmission: TH350
if you are just testign for pressure i would suggest going under teh hood. there is a schrader valve on teh fuel system to allow for pressure checks.
jsut turn teh key to the run position and then push in on the valve a little. if it squirts fuel you have pressure.
if there is a system pressure problem start with teh simple things, put on a new filter and then check for voltage. make your voltage check at the tank end of teh system, since that is where you are concerned with getting power, that is teh logical place to check.
hope this helps
later
tim
Old Sep 11, 2004 | 02:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The pump isn't working njspder, that is why he was looking for the test plug.
Old Sep 12, 2004 | 04:03 PM
Car: 1990 Formula
Engine: 355
LS1 pump is in it, working and running great now
Old Sep 12, 2004 | 04:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you wind up having to replace it?
Old Sep 13, 2004 | 06:10 PM
Car: 1990 Formula
Engine: 355
:lala: Correct
92camaroJoe
Jul 29, 2023 07:57 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
