Aftermarket cam VS. LT1 cam?
Old Oct 17, 2004 | 08:46 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Here in the near future i am going to be doing a Cam/Intake Swap and try to get in the 14's. My question is, what if i was to get an aftermarket cam with the same specs (Lift, Duration, all that) as a LT1 cam I would get the same results right?
Old Oct 17, 2004 | 09:01 PM
25THRSS's Avatar
If you copied the specs I would say yes, but why? There are much better cams out there.
Old Oct 17, 2004 | 10:51 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
What do you mean?
Old Oct 17, 2004 | 11:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
So many grinds, so many options, lifts, durations, the options are countless.
Old Oct 18, 2004 | 11:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you are doing a head swap would not waste your time on an LT1 cam. Chances are that your new heads would allow greater than .480" lift (not if you use un-touched GM castings though). The LT1 cam is nice when you keep the stock heads. Better heads will allow for a biger cam. Cam specs should be based on intake and head combo.
Old Oct 19, 2004 | 12:21 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
stock heads are sheit, i've been reading alot about them lately, you're much better off finding used TPI heads, vortecs, or a whole new engine for that matter.
-chuck
Old Oct 19, 2004 | 06:15 PM
25THRSS's Avatar
Even with the stock heads, lift isn't the only thing to consider. There are a lot better cams out there than the LT1 cam for the stock heads for lift, duration, etc. Unless money is a big factor, I'de go with another grind from comp or another reputable company that will yield better results in the end.
Old Oct 19, 2004 | 07:36 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i recently instaled an l98 cam inplace if the stock cam and although i need some chip tunning when combined with my other mods to get it to run half way decent you just adjust the fuel pressure. i have noticed a big differance even though i dont even have a good tune right now. 305 tpi heads awould also be a good upgrade to do with any cam upgrade espically if you do some minor home porting amd you already have doen exhaust work.
Old Oct 20, 2004 | 08:59 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
The only reason i say LT1 cam is because thats what everyone says to use. I wont be changing heads anytime soon, just cam and intake, and im not sure yet but i might switch to carburated.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Aug 29, 2015 09:51 PM
theurge
Aug 21, 2015 12:46 PM
