base timing for the lo3
Car: 1990 firebird formula
Engine: V8 305 TBI
Transmission: TH700R4
just need to know what the base timing needs to be set to for my stock lo3, the sticker under the hood is missing and I have heard many different things from many people. just want to know the correct answer
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The stock setting is zero and thats what your sticker would tell you. I would go with 2* or 4* advanced. Check out the section on timing in the new to TBI sticky up top.
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
This may be a "stupid" question...but lookign at that sticker made me think about something.
If I set my timing with the car in park......vs with it in drive.....any difference? I wouldnt think there would be but....jsut something I sorta thought about when looking at that pic of the sticker.
d
d
Car: '90 RS
Engine: 377 LSX
d
d
Car: firebird '89
Engine: 305 tbi
Transmission: it works I'm happy
I had the same thought. I've set my timing in park every time. I'll remedy that in five mins. but does it make a difference just so I know and its on the thread?
As long as you had the EST wire unplugged it makes no difference if you set it in drive, park, neutral, reverse, at idle, at 3000 RPMs or bouncing off the fuel cutoff with the engine screaming it's lungs out.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I would guess that sticker is "dated"... meaning GM is too cheap to change it.
Back in the days of carbs it made more sense to set the base timing in Drive because the RPMs would drop slightly by increasing the load on the engine.
Still funny to see.
Still funny to see.
