crappy gas mileage
Car: 1989 camaro
crappy gas mileage
well all the sudden i am now getting about 130-140 miles per tank and i used to be getting about 220. and i cant; figure out why. does anyoen have any idea's ?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by kammi10
hmm o2 sensor?
hmm o2 sensor?
Car: '90 RS
Engine: 377 LSX
prolyl a dumb question i should know but where is the sensor at and how much does one usualyl cost
Car: 1991 Chevy Camaro
Engine: 305 TBI
The oxygen (O2) sensor is located in the driver's side exhaust manifold. It's kinda hard to see sometimes from the top, but if you look down past the spark plugs, before where the exhaust manifold meets the Y-pipe, you shoud see it. They cost between $10 and $20, depending on the company. Some people have problems with the $10 Bosch sensors, and instead get the $20 AC Delco sensor, FYI.
Car: '90 RS
Engine: 377 LSX
is it eiser to change from the bottom of the car or from the top and how hard is it to change
Engine: 305 TBI
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
why do you need to change the stock one? just kus it sucks? my gas mileage is pretty crappy once in a while... not to get off topic... but how important is changing your PCV valve? and what purpose does it serve... it might be a coincidence but it seemed as tho my car is runnig a little funny since i changed it
Car: '90 RS
Engine: 377 LSX
Your PVC ventalates the crank case and relieves any built up pressure. As long as the little thingy rattles in the PCV than it is fine. If you are unsure go buy a new one. It may be the cheapest part to buy.
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
hmm yea i guess ill just put the old one back in... i replaced it yesterday just because it was 2 bucks and is easier than opening your hood to your car to replace... lol.. .ill juse keep the new one for the 355 same thing prob
Glowsock
Sep 11, 2015 11:09 PM
