Boost with TBI
Old Dec 23, 2004 | 09:22 PM
25THRSS's Avatar
Boost with TBI
If you were to run a roots style blower, like a Holley 144, at around 4-6 psi, how would you actually get the computer to sense boost. I do not want to run an FMU. Is it even possible to do with GM TBI and a roots blower?
EDIT: Not sure if a 2 bar map would even help since it would be a suck through setup instead of a blow through, with the TBI on top.
Old Dec 24, 2004 | 02:52 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
No expert on boost, but in theory, the roots blower should make the motor appear bigger to a carb or tbi thats parked on top. You could just try to tune it like you would any other motor and the extra needed fuel would be incorporated into the VE table.
Old Dec 25, 2004 | 01:08 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the other option is to use the 749. It already has the tables set up to run boost. And there are several people already using it to run TBI injectors.
The thing I worry about, is providing enough fuel, even with the BB injectors, I don't know that it would supply enough fuel for the 400-500HP that one of those little blowers is capable of.
For what its worth, I really thought about doing this a roots blown TBI project, before the TT bug hit me. I think it could make for an absolutly wicked little street mouse.
Old Dec 25, 2004 | 01:18 AM
25THRSS's Avatar
But with a roots blower, as opposed to a turbo or cent. supercharger, how would the map sensor even sense boost? There really is no way, so the 749 would be pointless right?
Old Dec 25, 2004 | 01:40 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Well maybe in that regard, but it would still give you much much better fuel and timing control than a TBI ECM. The tables extend much higher in the RPM range. It also has the fast baud rate for data logging and just the fact that its a P4 puts it way ahead of TBI ECMs.
Old Dec 25, 2004 | 06:12 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I have the 7060; it is TBI and P4
Also, the program I'm using goes to 6400.
Old Dec 25, 2004 | 08:48 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Just run the boost sensing line, to between the blower, and manifold.
For a boosted application, the 749 is the way to go, IMO.
Old Dec 26, 2004 | 01:48 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Exactly, with the case of the roots blower, you would need to get your the pressure for the sensor from the manifold instead of the from the TB unit. not a major change at all. Really, any option other than a computer really meant to work in a bosted application is pointless, you are either going to loose the ability to compensate for boost, or lose resolution with your other options.
Old Dec 26, 2004 | 11:16 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I don't think it was mentioned above, but the 749 uses a 2-bar map sensor, if that was your questions. So it can "see" to 14 psi, there is a patch out there some where to run a 3 bar sensor so 28 psi is an option, but not with a small roots blower.
Old Dec 27, 2004 | 02:40 PM
25THRSS's Avatar
Is the 749 a direct swap for the 746 ecm? Can you reuse all of your stock sensors?
Old Dec 27, 2004 | 03:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
you will need at least a new MAP sensor, I'm not sure what else you will need. I think that you need an injector driver out of the turbo 4cyl. application. Then you will need to repin your harness. I don't have all the info with me, some searching on the DIY board should give you more info that you need. I'm busy packing and getting ready for my trip to arizona, so I dont' really have time to do too much searching for stuff right now.
Old Dec 28, 2004 | 02:55 PM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
As mentioned, you'd want to use a "new" MAP sensor. The only other sensor that you might need would be a MAT sensor. I don't know if the 746 ECMs have these or not. Further, even if they're present on the 746, you'd want to make sure you're really measuring "Manifold" temperature rather than the temperature pre-blower. There are adjusments to timing performed based on manifold (post-blower) temperature you'd want to take advantage of....
All other sensors should swap with no problems.
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Glowsock
Sep 11, 2015 11:09 PM
Doobie52
Sep 11, 2015 06:19 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
