how frustrating
Old Oct 30, 2005 | 01:12 PM
sp63
Guest
Posts: n/a
how frustrating
i was doing the free afpr mod right. and i got it all drilled and ready to put back together.
the gasket broke on the injector pod (both parts, near the back and the front).
so i pieced it back together and gave it a try. nope! sprays gas out the back gasket area.
i wlak a mile to work to catch a ride to auto store.
all rtv's recommend not using on gas areas...
so i get this sheet of gasket material.
i spend like literally 5 ****ing hours trying to cut out the right shape for the major part of the injector pod.
finally get it looking GREAT.
carry it out and put it on car. HOORAY the back end doesnt spray.
just the front.
i just worked 10pm to 6am (7 am since D.S.T.) a 9 hour shift. i have to work again at 10pm tonight. im so ****ing frustrated.
sorry to rant.
Old Oct 30, 2005 | 03:27 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I have like 6 of those throttle body gasket kits laying around with various gaskets and stuff missing. The worst one are the injector o-rings, because they expand once fuel/heat touches them and won't go back in. It's a real PIA when doing tuning with different injectors.
Old Oct 30, 2005 | 07:02 PM
sp63
Guest
Posts: n/a
i have to WALK to work tonight.
this ****ing BLOWS.
sunrise chevrolet BETTER be able to order this gasket i need.
**** i bet its like 50 bucks for it too. *** DAMNIT.
Old Oct 30, 2005 | 07:47 PM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
go to napa, or local autoparts store and get a gasket kit. it prob cost like 20$ maybe?
Old Oct 30, 2005 | 08:28 PM
Car: 91 RS
Engine: 350 TBI
Yeah, if that much. Any Napa or Autozone should have it.
Old Oct 30, 2005 | 09:02 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
autozone has kit without the regulator diaphram in it for about $6...and the part#is.....gp sorenson 96-3013A...hope that helps it saved me alot of trouble and money
Old Oct 31, 2005 | 12:24 PM
sp63
Guest
Posts: n/a
ARGH omfg you kidding me? i JUST got a 20 dollar one at a store with a big discount cuz im a student.
anyways.
i donth ave a fuel pressure gauge and i turned the screw maybe 1 1/2 turns AT the most. (made the spring more compressed) and now the car feels funny. its slowerr on the low end, but high end feels better?
Old Oct 31, 2005 | 12:49 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Is there a reason you are upping the fuel pressure? If you have a stock motor, there is no need to make this change.
Old Oct 31, 2005 | 07:58 PM
dwillis's Avatar
Axle/Gears: 3:08
turn it back one turn and you will be fine.its probably running rich now...you could advance your timing a little too..the factory always retards timing for fuel economy and to cover themselves
Old Nov 1, 2005 | 09:03 PM
sp63
Guest
Posts: n/a
my timing is set at 6* with the little plug unplugged.
i run 93 gas.
sometime this week im starting my nitrous install. THATS why im upping the fp.
also, the car is like.. feeling better everytime i drive it. the low end is back to where it was? and the top end feels so much better. it.... feels stronger, but feels rich at the same time?
Old Nov 2, 2005 | 12:25 AM
Dewey316's Avatar
Car: 1990 Camaro RS
why are you upping the FP for nitrous?
Old Nov 2, 2005 | 09:31 AM
sp63
Guest
Posts: n/a
because i did a search and everyone said to to make sure it was at least 15psi.
also searched and found that the fp was stock between 12 and like 14 or whatever.
Old Nov 2, 2005 | 10:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
You found a thread with bogus information.
At 15psi of fuel pressure, the jetting from NOS for the TBI kit will be VERY rich (ask me how I know).
I'm not trying to be an *** or anything, but you are better off with your FP at a stock setting, why give up driveability all the time, in hopes of making your nitrous perform a little better (which it will not).
Set your FP back to stock, see how the car runs. With the stock FP, the NOS jetting will still be a hair on the rich side, as they jet them of the safer side of things, not always the optimal side of things.
The reason you are having problems at low RPM's is that you are dumping the gas in, maybe even to the point of fouling the plugs.
Old Nov 2, 2005 | 03:20 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Yeah, listen to Dewey, he knows what he's talking about with setting up nitrous on these cars. As far as running nitrous, maybe I'm one that likes to live on the safe side, but I don't think I would ever run it without knowing for sure I was getting all the fuel pressure i needed. This means, I would want to install a pressure gauge to read what it is under load. Honestly, I probably woudln't run nitrous without replacing the stock fuel pump with a Walbro unit of the like, but maybe that's just me.
Old Nov 2, 2005 | 05:13 PM
Dewey316's Avatar
Car: 1990 Camaro RS
That is very good advice BronYrAur.
As for testing the fuel pressure. What I did, was use a tap into my fuel lines, that tap is a -4an line, the line there runs to my nitrous noid. The standard GM fuel pressure port is a -4an fitting, so it works well. To test it, I just use a -4/-4/-4 tee, and I can hook up a FP gauge, and also run the car, with the nitrous.
(Picture for reference)
gta892000
Aug 11, 2019 11:16 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
