Hurt the 305
Car: 1983 G20 Chevy
Transmission: 4L60
Hurt the 305
Well seems that I have hurt my 305. Took it to the test and tune last night. Racing a Civic, pushed it to 5,500+, suddenly lost alot of power, and picked up a miss. Will have to post pictures when I strip it down. From the initial appearance, I a have blown a head gasket. No mechanical noise or chunks of metall, but milky looking oil, and lower than normal compression in cylinder 5 and 7.
Car: 1983 G20 Chevy
Transmission: 4L60
I look at it this way though, it gives me a chance to put on my newest pair of 193s onto it. It will reduce my compression from 10.3:1 down to about 9.4:1.
Car: 89 K2500
Engine: 383 tbi
Transmission: built 700r4
Axle/Gears: 4.10 14 bolt
thats a pretty good drop in compression. do you think you'll lose much power? how ported are those 193s......cuz knowing you they have pretty extensive porting. i definately should have ported mine a lot more. i even had them off over thanksgiving break and i didn't think to do it.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 89 K2500
Engine: 383 tbi
well then bonus that you'll end up w/ more power. can't go wrong with that. still sucks changing out heads in the frame though...........and it especially looks fun doing it in a full size van.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
5,500 rpms and thats all it took? (I understand they start losing power around 4) But i've taken mine to 6,000 on accident (tires spinning) with no problem..
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1983 G20 Chevy
Transmission: 4L60
The postmortem! I started at 12:00 today and got finished at 3:30. 3.5 hrs=not bad at all for both heads in a van. Well the engine had a blown head gasket between 5 and 7. Number 7 had a burned exhaust valve. Both heads had cracks in them????
As always I am short on time as well as, I am tired of messing with this 305 and any rebuilt engine for that matter. I am going with a GM Goodwrench HD 350 TBI crate engine for medium duty trucks. Thats right a Motorhome/Dumptruck/Schoolbus engine is going into my van. It has a forged crank, forged rods, 4 bolt mains, RV type cam, Swirl Port heads with oversized exhaust valve stems and sodium filled exhaust valves, larger diameter pushrods, 8.7:1 compression ratio, 210 FWHP @ 3,800 and 315 ft/lbs @ 2,800. I am using my Edelbrock 3704 intake, stock sized ultimate TBI moded TBI, low-restriction exhaust, stock air cleaner and intake assembly, K&N filter, eliminated the clutch fan, underdrive crank pulley, and a custom tune on the EBL. It should make around 235-240 FWHP @ 4,500 and 340 ft/lbs @ 2,800. It is rated to pull up to 20,000 lbs GVW on 89 octane gas. It comes with a 3yr/100,000 mile warrenty, all the tin, a harmonic balancer, a $100.00 rebate on the core charge, and the local dealer has one in stock for $1740.00. Don't hold your breath, they have been discontinued and this is one of the leftovers.
12514811 5.7L 350 (HD) medium duty truck 4 bolt main One Piece Seal, Steel Crank is what Sallee chevrolet had to say about them.
Car: 89 K2500
Engine: 383 tbi
that should be a good long lasting engine. those sodium exhaust vavles aren't cheap. i put a set in some 429 ford truck heads that i did a valve job on, and they were like i think 60 bucks a piece.
Car: 1983 G20 Chevy
Transmission: 4L60
If it can see sustained WOT in a 66 passenger school bus full of kids for 100,000+ miles, I doubt I can hurt it, short of over-reving it. Over-revving it would be kinda hard though as it probably won't have much left at 5,000+ and I can dial in the fuel shut-off at whatever the recomeended max RPM is from chevrolet. Should be around 5,200 rpm or so. I'll probably set up the governor to shift it around 4,800.
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
Originally posted by va454ss
What happened with this:
https://www.thirdgen.org/techbb2/sho...hreadid=340412
Are your ported 193's going on the next motor or would you be intrested in selling them? *dibs*
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
i accidently put my camaro to 6,000 today.
This 4 cylinder s10 blazed by me going about 40 when i was going 15 and i dropped it into first.. and i glanced over at his truck forgetting i put it in 1st
. I then happened to glance at my rpms and i said ****! it shifted into second real hard.. I felt bad for my ole' maro
Yea.. i felt like a tard.. but i was happy it was ok.
Yea.. i felt like a tard.. but i was happy it was ok. Junior Member
Car: 89 K2500
Engine: 383 tbi
when my tranny was going out, i was on the interstate doin about 85, and it double shifted down into 2nd gear, and rapped my stock LO5 to over 6000. i almost pooped. the next day it wouldn't shift out of first. these motors can take crap like no other.
