416 heads
Car: 87 iroc
416 heads
I'm thinking of buying some 416 heads but they have been cleaned up and the springs are like new, so the question is will the lt1 cam and 1.6 roller rockers work with the stock 416 heads? Also, will these heads just bolt on to my 92 lo3, I know the intake is different which I got cover with a 86 and lower rpm intake. Wondering what head gasket and intake gasket get for it, like the tbi gaskets or the tpi gasket. Thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would be leery of running the LT1 cam with 1.6's on the cstock guides. You can get away with it if you switch to an umbrella type valve seal. If you want to use a positive seal and run a lift value over .480" you will have to have the valve guides cut. Running 1.5's may be the better choice.
Any reason why you are going with the 416's? Unless they are ported your stock heads will make more power below 4200 rpm. With only the LT1 cam you won't really see any improvements with those heads (unless ported).
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
And, if you port the 416's, use the RPM intake, 1.6 rockers, and LT1 cam, you'll most certainly need to get a chip burned if keeping TBI - especially if you add headers.
Car: 87 iroc
Do I need a new fuel pump if I have the lt1 cam and the new heads on? The fuel pump is a new stock one. Can 416 flow the same or better then the 081 heads when ported and 3 valve job? Also if I have air to fuel gauge would that work the same as a wideband o2 sensor?
Car: 87 iroc
Also will the 416 bolt on without probs. I also have the right intake for that year heads perform rpm intake. With tuning what kind of hp number is it going to put out?
Car: '90 RS
Engine: 377 LSX
The 416's are the same basic head as the 081. The 081's were a later version that accomodated the different intake pattern and center bolt valve covers. I also believe they had non self alligning rockers.
The heads will bolt right up but you will need different valve covers. The A/F gage that you have is not the same as a iwde band O2. The gage you have reads the narrow voltage values of the stock O2 and lets you know at part throttle if you are rich or lean. It is very inaccurate to the say the least and is considered a "narrow band" O2 (small range). A wide band 02 will tell you your A/F range over every RPM point. It is very accurate and crutial for WOT tuning.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
so shifty are you saying that I couldn't use my 1.6 rockers on the 081 heads.because they are self aligning i believe.
Car: '90 RS
Engine: 377 LSX
Car: '90 RS
Engine: 377 LSX
Will the stock fuel pump handle these mods with out a prob.? Its got a new stock tbi fuel pump right now.
It will be close but I would plan on replacing it soon. Sooner or later you are going to want/need to increase your fuel pressure to a level that the stock fuel pump will not be able to support. FWIW, I will never do a cam swap with the stock pump.
Car: '90 RS
Engine: 377 LSX
How much fuel pressure needed for the lt1 cam?
It depends on what injectors you run.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
