lower temp fan switch
Old Apr 3, 2006 | 03:33 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I just ordered a 195 degree on and 185 degree off fan switch for my LO3 and just wanted to make sure im not hurting the engine or computer. Is this fine guys? Thanks.
Old Apr 3, 2006 | 03:47 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Yep. Along with a lower thermostat this is a good thing to do. My stat is for 180* (I think).
Old Apr 3, 2006 | 07:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Have you changed thermostats?
Old Apr 3, 2006 | 08:49 PM
Engine: LB9, LB9
not yet, is it necessary right away and does it rquire tuning to change the thermostat?
Old Apr 3, 2006 | 08:59 PM
I'd throw a 180* one in there while you are working on it. Tuning would be best but you'll be ok without it...
Old Apr 3, 2006 | 09:05 PM
Engine: LB9, LB9
Ok well im slam broke since i ordered wires too, so could i drive it for a while with this switch and the stock thermostat?
Old Apr 3, 2006 | 09:12 PM
Yah, but a thermostat is only about $5 or less...
Old Apr 3, 2006 | 09:16 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A 180° thermostat on the stock tune will be fine. I would not go with anything lower.
Old Apr 4, 2006 | 05:37 AM
Engine: LB9, LB9
Ok well got the 180 thermo, anything else?
Old Apr 4, 2006 | 10:43 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
I just put that same fan switch in my 89 RS TBI and i love it, my car used to run up above 210* or warmer before the fan would turn on and only cool down a little and shut off, now i dont think my car gets over 200* anytime, its great! i love it and i have a regular thermostat in it!
Old Apr 4, 2006 | 12:43 PM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
Where did you get the switch??
Old Apr 4, 2006 | 01:43 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
I got mine off ebay from this guy:
http://cgi.ebay.com/ebaymotors/NEW-T...spagenameZWDVW
But you can also get them at summit also:
http://store.summitracing.com/partde...5&autoview=sku
Ebay is about $20 cheaper though, and thats where i got mine and it works great!
Old Apr 4, 2006 | 08:59 PM
Engine: LB9, LB9
I got the JET one from summit for $38 because my connector broke too.
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
TA8487
Aug 16, 2015 12:21 PM
