TBI engine bay pics needed
Old May 26, 2006 | 12:33 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
OK folks, little bro just picked up a very nice 92 RS. He's wanting to detail and dress up the engine bay and claims that he wants to try and hide as much of the wiring harness as possible. He's also talking seriously about pulling the a/c as it doesn't work and doing the delete swap. So here's the request: any of you that have gone to the trouble of rerouting, rewiring, or just plain removing the wiring harness from your TBI powered F bodies post a pic here. That way he can get some ideas and an idea of just what all will be involved. He said that he would use mine as a guide but since I'm swapping to TPI soon he wants to see as many as possible.
Old May 26, 2006 | 08:28 PM
HillbillyJeeper's Avatar
Car: 1975 IHC Scout II
Engine: 1967 Buick 340 with TBI
Here's one of mine. not the cleanest, but i still have smog equipment. Relocated AIR controls to the passenger fender, And heater valve delete. Still has A/C and ugly(need new) coolant and washer bottle. Stock wiring. Guys at the races were impressed with how clean it is. If you can get rid of the smog eqip, you can make it that much better. and delete the A/C
Old Jun 3, 2006 | 05:53 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
well, this is an old pic, quite a bit has changed, but the wiring is simpler and the A/C is removed and i just put an adjuster on the alt to make the belt work.
Old Jun 3, 2006 | 06:40 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not very clean at the moment, but I have alot more to contend with in the same space than you car/SUV guys do.
Old Jun 3, 2006 | 07:34 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
like what?
Old Jun 3, 2006 | 08:24 PM
DrummerDad's Avatar
Car: 1991 pontiac Firebird
Engine: 305 tbi, Lo3 (for now)
Transmission: auto
Axle/Gears: stock (for now)
Heres mine. Totally stock L03.
Old Jun 3, 2006 | 09:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by superbee
like what?
Lack of space. I have 20 things trying to occupy the same little area. Transmission dipstick, extra long engine oil dipstick, A/C, cruise wiring, cruise, throttle cable wrapping around engine from the front, wiring harness can only go one place, etc.
Old Jun 3, 2006 | 09:42 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
i dont have a pic for ya of my buddies car but his looks like a 60's model all you see basically is spark plug wires. Get open element delete the ac get rid of smog. Get a kit that puts your alt where your smog pump use to be you that will get rid of your pulleys up top. You can reroute your coolant hoses to get rid of that annoying vavle with the 3 outlets.
Old Jun 4, 2006 | 10:47 AM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
what about the ect wires, and tbi wires?
Old Jun 4, 2006 | 11:33 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Mine is pretty much stock too. Superbee's looks sharp. Almost can't believe it's a TBI.
Old Jun 4, 2006 | 12:44 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Thanks, ill try and get an updated pic, the tbi isnt all nasty now, and the wiring is better.
Old Jun 4, 2006 | 04:45 PM
WannaBeFast's Avatar
Chevy eXperimantal RS-7
Old Jun 5, 2006 | 10:46 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Here is a pic of my 1989 RS 350 TBI, check it out!
Old Jun 5, 2006 | 06:05 PM
useful idi0t's Avatar
Car: 88 Trans Am
Engine: LO3
Transmission: TH700-R4
Axle/Gears: 7.5 10 bolt 2.73 open
Hilbilly Jeeper, what did you need for hardware to relocate the air assembely? just heater hose?
also what did you do to the heater core manifold?
and that engine bay looks friggin awsome for a smogged TBI!
Old Jun 5, 2006 | 07:51 PM
Well, its not quite smog legal, with the open element on it. but everything else is. (if you dont tell them its a 350!). I just used heater hose relocate the AIR control, and some speaker wire. when i get a change, i get pictures up of where its sitting. As for the heater, i just pulled the control, and left it so its flowing all the time, and plugged the one outlet on the "T" on the hard line. Even today, at 95 or so, the A/C still blows cold, and thats with a off the shelf conversion kit to 134.
Old Jun 5, 2006 | 09:13 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
i cleaned up my engine bay with a new engine if that helps, all smog deleted
Old Jun 5, 2006 | 09:19 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
nice borsty
IROCZ1989
Jan 24, 2016 03:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
