hey guys
hey guys
hey im pretty new to the board, and im loving my 92 'maro drop top. have had it for about a year or so. im doing a build up project on the old 305 tbi. the engine only has about 90k on it and i just bought the tes system from edelbrock, cast iron vortec heads, comp cams xe262h, gm tbi aluminum intake manifold, and i know holley sells a tbi 670 cfm but dont know about that....so thats what im kinda doing right now, o and i just bought a new convertible top from topsonline.com....any comments on what i should do and dont want to hear just swap it with a 350.... when a 305 is a perfectly good engine to work on and build up
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
yeah i was looking at aluminum pulleys 3 piece set....jegs sells it for 159.99 kinda exspensive but meh...still looking also i have read that i can use a carb manifold like a performer rpm if i use a tbi adapter plate
Car: 1983 G20 Chevy
Transmission: 4L60
Laptop, Moates Burn 1 and the EBL will be your best friends with the mods you have in mind.
i have a question about a manifold, if i want to stay tbi and have vortec heads (cast iron 64cc combustion chamber, 1.94/1.5'' valves max cam lift .475) what would be the best manifold to use? was going to probably use the stock gm 454 tbi unit. i know gm makes a vortec manifold but its pretty expensive in the 350 dollar range from jegs
and i am also going to use a bigger cam from comp cams xe262h or 268 havent decided...what should i do?
and i am also going to use a bigger cam from comp cams xe262h or 268 havent decided...what should i do? Supreme Member
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Just use a carb intake and a TBI adapter plate, keep in mind that hood clearance will be a problem with some high rise designs like the performer RPM.
Like fast mentioned you will be very disapointed when your 1000$ worth of parts won't even make it out of the driveway. When changing as many things as you want to change DIY tuning is the ONLY way to go.
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
wow good stuff
i had the exact same plans as you. i already got the headers... but im dropping in a 350 anyways. b/c its free lol
i had the exact same plans as you. i already got the headers... but im dropping in a 350 anyways. b/c its free lol Thread
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
