Problems with RS
Old Sep 11, 2000 | 08:06 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
Problems with RS
Ok I hope this is a good place to post this problem:
For a while now my Mom has been having problems with her '92 RS (305TBI). It would fail to start at times but most of the time it was ok. Then one day it just would not start no how. Had to get it towed home.
The SES light came on do i hooked up a "code reader" and got a code 54. So I replaced the fuel pump & filter, no luck.Replaced the fuel pump relay, same thing, then replaced the fuel pressure regulator still no luck, as a last resort replaced the oil pressure switch and the darn thing still will NOT run!
I've done everything I can think of and am at my wits end. HELP!!!!
Anyone had this problem or have another iIdea of what I can replace?
TIA
-don
Black 87 Camaro T-Top, V6, 5-speed, Loaded
see my car at: http://www.geocities.com/iCamaro1987/camaro.html
Old Sep 11, 2000 | 09:48 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
have you checked the fuel pump fuse?
[This message has been edited by Pablo (edited September 11, 2000).]
Old Sep 11, 2000 | 09:49 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
btw im assuming your fuel pump is NOT coming on at all
[This message has been edited by Pablo (edited September 27, 2000).]
Old Sep 12, 2000 | 09:36 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
The Fuel pump worked once installed. But doesn't make a sound when trying to start, turned out that the original fuel pump wasn't shot either. I think her aftermarket immobilizer (Mytek) is causing a problem but the intallers down right deny it
Old Sep 12, 2000 | 11:50 PM
RSS's Avatar
RSS
It could be your security system acting up. My car will not start sometimes. Is her car cranking over or is it just nothing when you turn the key?
92 RS (Rice Sucks) 305 TBI 5 speed T-tops AC stock 16 inch aluminum wheels
14X3 open element, 3.73 gears, posi, dual 2 inch bendable exhaust, no mufflers or cats (kinda loud), 160 thermostat, relocated IAT, weight loss, lots-o-free mods and one hell of a crazy driver.
"Friends don't let friends drive Mustangs."
Old Sep 13, 2000 | 12:09 AM
pianiy's Avatar
Just a suggestion, maybe it has nothing to do with the code, could it be your starter? or a loose connection to it? check your wires to see if you have good connections everywhere...
just my $0.02
'91 Firebird
305/TBI/700R4/T-tops all stock
K&N Air Filter
Pioneer DEH-P8200R
Pioneer 6x9's
Kenwood 8" Tube
'87 Firebird
2.8L/MPFI/700R4/220K Miles on its original, never been rebuilt engine!
Car being parted and sold, just ask what I have.
Old Sep 13, 2000 | 12:34 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
It Cranks fine, like it wsnts to start but when the TBI unit is checked there is no gas coming out. I'm almost positive that it is the Security System so I'm going to remove it today.
-Don
Ps anyone wanna buy an Immobilizer cheap?
Old Sep 21, 2000 | 10:33 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
clogged injectors maybe? I had one that was stuck when I put in the 350 and the other one wouldn't fire because of it. I never got a trouble code from it though...
-Mike
Old Sep 27, 2000 | 03:32 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Well, I got it all figured out! Turned out that the relay that I changed was for the immobilizer and not for the fuel pump! I changed the PROPER relay and now the car fires up everytime. Incidentally, I learned that TBI (maybe TPI/MPI) have a "feature" that allows the fuel pump to work if the oil pressure reaches about 4psi thats why the haynes manual says to check your oil pressure switch if the fuel pump doesnt work.
Thanks for everyones help
-don
Old Sep 27, 2000 | 04:04 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Yep i went through all that too, glad to hear you figured it out.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
