Removing the cat HELP!!(Its stuck)
Old Dec 9, 2000 | 01:32 PM
BLUE92RS's Avatar
I was taking of my cat the last night and it took me a while to get all the bolts off. I finally got all the stupid clamps loosend even the little one going into the cat which i am assuming was the o2 sensor. What i was going to do was take all the $hit out of the inside and put it back on. That cat back pipe came right off but when i pulled on the cat i realized that it was stuck on the pipe going in. I banged on it pretty hard but itwas still stuck.
So any ideas on how the hell i get it off???
Old Dec 9, 2000 | 03:45 PM
chevyboy07 91's Avatar
spray some WD-40 in there and keep on beating. ALso, try twisting the s h i t around every once in a while. The key is that BFH though. IMO
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Old Dec 9, 2000 | 05:37 PM
NJ SPEEDER's Avatar
you may also want to take a hair dryer or something and get the cat warm. this will expand tthe pipe a little and may help it get on. if that fails go buy a bigger hammer
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
The stock cam will go 13's!!!!!!!!!!!
The car is going street strip for next season. 13's here i come!!!!!
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall),Steve Spohn Rear Rig( all rod ends), Poly Front Bushings,Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
Old Dec 9, 2000 | 05:50 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Burn that son of a b*tch off! YEAHHHH!
Well thats what I did. Took a torch to it, burnt it off and put a hold new 3" pipe in there.
Eric Natzke
91 Firebird 305 TBI
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Dec 9, 2000 | 10:35 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
A good cut-off tool works well too
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, SLP 1 5/8" headers, and a few other things.
Old Dec 10, 2000 | 01:27 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
ramming it out? i never thought that would be a good idea. ruin a perfectly good cat. well, that and wont that cause huge turbulance in your exhaust flow, or does that matter? That and how would you get all the peices out?
Old Dec 10, 2000 | 03:16 PM
BLUE92RS's Avatar
Well i got it off just used a screw driver and a hammer.
Usally you can pop out the screw that is on the cat but for some reason are cats dont have a screw so ill probably end up putting a straight pipe.
What is that little piece going into the cat is that the 02 sensor and i am assuming you dont need but you will get an error correct???
Old Dec 10, 2000 | 05:38 PM
snflupigus's Avatar
it helps your computer tune your motor. i think i have pics of one up on my site.
go to it is, then parts pics.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
