whats up with this "use your stock injector pod" with holley throttle body stuff????
Old Jan 10, 2001 | 09:34 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Does this really make a big difference? Sorry for my lack of knowledge on the parts ofg the throttle body, but what teh hell is the injector pod?
I am sure if I just went into the garage and looked at my throttle body I could figure it out, but why do that when you guys could just tell me? hehe.
No, but really...what is the difference? What does it help with?
-Brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Accel Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Jan 10, 2001 | 10:46 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
The injector pod is the thing on the back of the throttle body unit that holds the injectors (the injectors are considered part of the injector pod too). It has, I think, three screws that hold it on the throttle body unit. I'm not too sure on the specifics of modifying the Holley throttle body unit to accept the stock injector pod, but I do know the reason people do it. The general consensus here is that the GM type injectors are better than the Chrysler type injectors found on the Holley units. They can take more pressure (and display a better spray pattern?).
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Jan 11, 2001 | 01:55 AM
JPrevost's Avatar
Car: 91 Red Sled
That is very interesting. I didn't think the unit came with injectors and I figured it would have been GM if anything. Learned something new so I guess I'll call this a good day.
, Jon (91 RS too many mods to list), getting new engine in summer
Old Jan 11, 2001 | 02:30 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
screw holes are the same. no mod, just bolt on.
Old Jan 12, 2001 | 12:55 AM
Z28Maniac's Avatar
Are the 305 pods the same as the 350 ones?
'68 Camaro - Vortec 350
'85 Camaro Z28 - 305 TPI - FOR SALE
'91 Camaro RS - 305 TBI
Old Jan 12, 2001 | 01:52 PM
snflupigus's Avatar
yes, except that there are different injectors in them.
actually there are few different part numbers for injector pods, from what ive seen though, they are all the same from looking at them, their might be slight variances. But most likely not.
Old Jan 12, 2001 | 03:00 PM
Get Blown ?'s Avatar
Only thing you should have to do is tap a threaded hole for the air cleaner screw, since the Holley unit has it on the injector pod. Oh yeah, not sure but you might have to grind off two **** on the lower half of your GM injector pod or double stack injector gaskets to correct height. While your at it make your GM injector pods FPR adjustable. (see thirdgen tech articles for how to guide)
1989 Camaro RS LO3 WCT5 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
WARNING: overpowering a broken posi unit can lead to abusive behavior...
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
