Fuel Pressure
Old Feb 7, 2001 | 07:41 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Fuel Pressure
What would I feel if I wasn't getting enough fuel at WOT???
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Feb 7, 2001 | 12:37 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
ya. it wouldnt pull. might miss.
Old Feb 7, 2001 | 03:19 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
K, cause at WOT, I have a jerking sensation. You can feel it through the car, you wont notice it if I drove by you,
Old Feb 8, 2001 | 12:46 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
No one wants to even guess at what my problem might be??
Old Feb 8, 2001 | 03:00 PM
snflupigus's Avatar
ya, your car is missing, tune up time. and boost fp by about 1/8 inch maybe on your stock fp regulator.
Old Feb 8, 2001 | 03:04 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
The only thing I have not replaced was the wires. I did the oil, plugs, rotor & cap, O2 sensor. I also think I might have a vacuum leak.
Old Feb 8, 2001 | 06:09 PM
snflupigus's Avatar
coil? anyway, could just be the fuel pressure thing. or maybe your computer is sensing knock and retarding your timing at wot and that is causing it. Best thing to do now would be hook it to a scanner and monitor have somebody monitor it at wot. obviously you dont want to be driving at wot while reading a scanner
Old Feb 8, 2001 | 06:12 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hmm, I don't know man. I wish I could help. In your tune ups though, don't forget to replace ur fuel filter too!
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Feb 8, 2001 | 06:41 PM
Zac's92's Avatar
I have had my car on a scanner and with 0* base timing I was getting knocks counts at WOT. The stock computer doesn't react fast enough when changing the timming to make it feel like a "jerking sensation".
Zac Spalding
Old Feb 9, 2001 | 11:15 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I have replaced the coil, and fuel filter aswell. I forgot to mention that. The thing with the computer sounds really close, what can I do to fix that IF it is my problem??
Old Feb 9, 2001 | 12:49 PM
snflupigus's Avatar
i think, though i could be wrong,
but i think zack is saying that the computer doesnt act fast enough to cause a jerking sensation when making timing changes because of wot knock.
Old Feb 9, 2001 | 06:55 PM
JPrevost's Avatar
Car: 91 Red Sled
If you're getting knock at WOT then it could very well be your EGR. The EGR heats up your intake so the combustion chamber has less air/fuel, this means you get a cooler chamber and so the advance can be set higher. When the EGR isn't working your engine will be running with a cooler intake and so in theory you'll be making a little more hp but when the ECM advances the timing to get better gas milage it'll sense knock and retard back down just to get rid of the knock. That is why most aftermarket EFI engines need a custom burned chip. It's not as easy as everybody thinks..."I'll just mess around with the EGR..." it isn't that easy. I'd also look into the fuel filter because that can be a problem too, if you're injectors don't get enough fuel you're engine will be running lean at high rpm and that means a very hot engine and then the advance problem begins and makes your engine run like crap at WOT. I think that's about it, get boht the EGR and fuel filter checked out, then get back to us.
, Jon (91 RS too many mods to list), getting new engine in summer
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
