what plug wires, lo3+2055
Old Jan 5, 2007 | 04:41 AM
streetassasin's Avatar
Car: 2001 SS
Engine: bolt on LS1
What plug wires will fit and not burn up when I get my hooker 2055s on my lo3?
Old Jan 5, 2007 | 01:37 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Just get some cut to fit msd 8.5 wires.A blind retard can do it.
Old Jan 5, 2007 | 11:53 PM
Car: 2001 SS
Engine: bolt on LS1
Would I want straight or 90* ends?
Old Jan 6, 2007 | 12:04 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Get a set of Nascar Select Borg Warner #ch8833.
They are 8mm and 90* boots (low resistance)
Old Jan 6, 2007 | 01:08 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
MSD super conductors, HEI 90* boots, universal.
no problems here. get some of those fancy plastic clips while you're at it.
Old Jan 6, 2007 | 09:29 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Any aftermarket set will suffice for your needs. MSD, Accell, Mallory Tailor, and Moroso all make good sets. You want 90° boots.
Old Jan 6, 2007 | 11:14 AM
Car: 2001 SS
Engine: bolt on LS1
On the distributor would I get 90* HEI, 90* socket, or 90* male terminals? I have also heard that you can run the wires from a SB-Chevy Truck 1985-95 5.0L/5.7L is this true?
Old Jan 6, 2007 | 12:22 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
DynoDon,
do you have any actual numbers on those BorgWarner wires ? I think they're the ones I may be running in my car, those or the BorgWarner 7mm, but I have no clue how they perform compared to Accel or MSD.
Resistance ... RF ... etc
Old Jan 6, 2007 | 07:53 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
get plug wires for 89' 1/2 ton chevy pickup with a 350. those are the wires you need. all 90* boots.
Old Jan 6, 2007 | 10:12 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Those are the wires Dyno Don mentioned. They're 8mm instead of the 7mm that the aftermarket specifies for our cars. They're also low resistance and inexpensive, about $35 at your local parts store. All the engines Dyno Don builds here in SoCal use those wires and we havent had any problems.
Old Jan 6, 2007 | 10:20 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The factory plug wires for a TBI fullsize van are all 90* boots and the wires are slightly longer than a TBI truck.
I have Accell wires that are cut to fit.
Old Jan 8, 2007 | 02:45 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Oh ok, the TRUCK wires, ok.
Would explain why mine are 7mm while you guys were refering to 8mm ones. Still talking about the grey wires with black boots, correct ?
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
