cold air lo3
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
cold air lo3
i wan to run a high flow filter but ive been told that it actually hurts the motor because it pull in hot air from under the hood. does anyone make a cold air induction kit for the lo3? how else could i simulate cold air intake? anyone make the 82-92 ss hood functional, would that work?
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Drawing of my idea:
Im in the same boat my friends, Im going to use my Iroc grill as an inlet and fab something up! good luck with yours! Let me know what you come up with
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If you live somewhere constantly hot like AZ, then the CAI will definatly help. The carb hat and ***** intake tube is an easy way to go. I have that as well.
If in cold climates, though, its best to pull warm air at all times as the TBI wont run as well with varying intake temps.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Where can I get one of those assemblies that covers the TBI like that and allows 4" pipe or whatever to be attached? I'm dying to ditch my stock L03 setup.
Car: 1983 G20 Chevy
Transmission: 4L60
I have been meaning to relocate the air filter down to right below the evaporator box on the passenger side away from the hot air. The Intake Air Temperature is hitting around 135-140* on a 85* day, which I know is killing some HP. Just have not had time to do it.
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
I got my Chromed Bonnet and tube from my local speed shop. $99.00 Canadian for the 4" bonnet, then I got a 3" intake tube and made it all work
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I am thinking of something like that turned to the front with a ram intake filter and box I saw for tpi.
Car: 1983 G20 Chevy
Transmission: 4L60
My understanding is that it will fit under the stock thirdgen hood just fine.
Another member had one a while back that was plumbed to a TPI style air cleaner up from. Claimed it worked well.
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Car: 91 Trans am
Im loking into a similar air intake and would like to keep all the factory sensor's and hose's and if possible an alternaty to the thermac function.
Can you help me?
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I was not one of the first, but here is my cadillac/tpi air intake.
The difference in air intake temperatures of this hybrid and an open element is large (40+). You will have to remove about half an inch from the cadillac bonnet to clear the stock hood.
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Here ya go...Mine, love it.Old pic, alot has changed under there, but I can say this REALLY woke my motor up..Plus it sounds so good now.If you have questions PM me, Tom
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
galileo, that setup looks pretty trick. before you made that air intake did you ever try an open element? i have one now , and on hot days or after running the car for awhile it seems to lag in power.
also another thought i had is that it would be cool to have a cowl induction hood that sealed with the air cleaner only letting air in from the cowl like some 69 z28's had. anyone ever tried this?
Car: 89 RS, 92 Z28
No, I went from stock to this...It breaths thru 2 gutted TPI boxes, and a K&N filter in the round part..There is aluminium duct work at the front of the car to direct more air in (Looks cool from the front), it is true ram air...And by sound, I mean you get that cop car kinda noise, like a big four barrel kicking in...I can truly say, it has made more of a difference to the way the car runs than any mod up to that point...Tom
Car: Camaro RS 1992
Engine: 305 TBI
Transmission: TH700R4
Just one question.
I know that hot air is the ennemy of horsepowers, but the flow rate of an open element is more important than a CAI one, no? Even if the air is much hotter under the hood, I think an open element like KN Xtrem is less restrictive than a CAI...
Can you tell me the air flow rate for an open element and for a CAI.
Car: '92 firebird
Engine: 305 tbi
what differences do the camaro/firebird have on the air intake for the tpi? im guessing the camaros had better airflow
Car: 89 RS, 92 Z28
What is really needed on a setup like mine is to increase the opening in the round breather case..I did open it up some, but as I mod my motor more, I will enlarge it even more..That way, I will have the best of both worlds, cold air, and lots of it......I am thinking about a K&N top for my breather, that way I will still get cool air from the ram air setup, but will get more air flow from the top..I know that at low speeds I will get more hot air in, but as speed increases the cool air flow will increase...Also, I have removed the rubber seal at the back of my hood, which lets hot air out alot easier...If I get the top, I will let everyone know what I think about it.Tom
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
saw your air set up , i am doing the same thing . used k&n 66-1401 on top ,
with a regular nut . stud was not long enough for wing nut . had to cut center out of metal lid , inside 3rd step on lid . there will be a gap with k&n lid that i sealed with foam tape [ no rattles with lid foam tape holds it secure ] . my question to you is what is your filter housing from or did you have to fab. it yourself ? would send a pic. if i knew how to of my set up . also what is the flex tube from ? i also have a white 89rs with "T" tops. they say great minds travel in similar circles?
speedy reply would be great . uncle tom , ms. gulf coast .
Car: 89 RS, 92 Z28
Just one question.
Car: 91 Trans am
Car: 91 Camaro RS
When I did it, I put the iat sensor where the pcv hose would have went in the cadillac bonnet. To do this I had to extend the wires roughly 12", and I had them exit the loom closer to the front of the engine bay. Then I put them in their own smaller loom and it now looks factory.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
If you click this link you will see a step by step of how to do a cold air switch. This is how I did mine and I love it. Immediate increase in HP.
https://www.thirdgen.org/forums/tbi/...i+tpi+cold+air
Car: 89 RS, 92 Z28
You want the sensor as close to the TBI as possible..(At least I think so) Mine is in the stock location...There is another one on the TPI box, but I have not tried it.....
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
would this work with an airgap intake? im having trouble already clearing my stock hood with a drop base on a stock manifold.
Car: 89 RS, 92 Z28
The filter case is stock, but not sure about the airgap, it is taller than stock...
Car: 91 Trans am
Car: 91 rs
Engine: 305tbi
Re: cold air lo3
thomas1976 where'd you get that big inlet(scoop) at. how'd you get the stock bonnet to turn the way you have it? liking the set up can you explain in detail
Car: 91 Trans am
Re: cold air lo3
The scoop is a experiment I build myself out of fiberglas.
The stock bonnet is not turned, I took the original inlet off and cut a much bigger hole in the front, dremmeld the silencer ring out and plugged the thermac activator.
It is not finished im just testing it. In the end im going to drill some 1" holes on the inside of the hood, its a trans am hood with the 2 griles.
I can e-mail you some pics of the bild up if you need.
Car: 91 Trans am
Re: cold air lo3
this works wonderfully!
ram air box #10x3S, 3" k&n, 4" turbo cuppler hose and self made snorkle.
http://www.cardomain.com/member_page...86_16_full.jpg
http://www.cardomain.com/member_page...86_17_full.jpg
http://www.cardomain.com/member_page...86_18_full.jpg
http://www.cardomain.com/member_page...86_19_full.jpg
http://www.cardomain.com/member_page...586_3_full.jpg
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Re: cold air lo3
hmmm i was thinking about getting a good bonnet.. and fiberglass the front tunnel thingy... reason why i asked hmmm
****.. once i get the car running... going to port the my backup heads... LT1 cam ... spacer... ported intake manifold .. .and.. maybe maybe.. exhaust
so i need to learn how to tune or find someone
Fast355, do you have ANY pictures of the mod to the intake manifold, where you remove the center piece to make it an open inlet ? I know one has to weld up the water passages ? How far down does one grind ?
Car: 91 Trans am
Re: cold air lo3
Vorgat, it is the #10x3S filter box from ramairbox.com
There is no place left for a tb spacer with this air cleaner assembly the problem is were the 4" inlet goes straight out.
But a carb bonnet should fit with no problem specially the spectre ones that is 3.55" high and has the 4" inlet slightly dropping.
Dont forghet the filter there is no place between the radiator and serpentine set up, but you could use the camaro tpi air intake essembly + filters.
Car: 1991 Camaro RS
Engine: LO3
Re: cold air lo3
oh i don't care about height .. gonna modify my Z28 fiberglass hood one day anyway
thanks for the info
*looks at website*
WHAT ? it's made out of fiberglass ? heck... i'll grab a Caddie bonnet and modify it using fiberglass then.. or even make a fully custom one
thanks for the info
*looks at website*
Axle/Gears: Posi
Re: cold air lo3
Here is a close look at mine.
From this ...
to this...
a tremendous increase in power...
From this ...
to this...
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
kyle5647
Aug 15, 2015 11:56 PM
