what does a stock automatic TBI run in the quarter mile?
Old Feb 22, 2001 | 07:35 AM
88firebirdTBI's Avatar
I went to the track this past sunday and i ran a 16.1. does that sound right? what should a TBi 305 run in the quarter? thanks
Old Feb 22, 2001 | 07:41 AM
89BlwnRs's Avatar
That's about right. I've got an 89 Camaro (5-speed though) with a cat-back, chip, and open air and I run 15.7 at best. Normally slightly higher.
Jason
Old Feb 22, 2001 | 07:44 AM
cobrakiller1989's Avatar
if thats stock, id say you ran extremely well. most of the stock L03's that i see run high 16's. I wonder if once you start modding it, if it will run better than someone else's with the same mods.
Old Feb 22, 2001 | 10:47 AM
It is not completly stock it has an open element and no cat. i am getting my headers put on this weekend
Old Feb 22, 2001 | 10:57 AM
305tbilo3's Avatar
My 91 Firebird 305 TBI LO3 ran a 16.18 bone stock. So youre doing good. My car now runs a 14.89. My mods are below.
Mods: K&N FILTERCHARGER, K&N X-TREME FLOW TOP PLATE, FLOWMASTER 80 SERIES MUFFLER, GUTTED CAT, EDELEBROCK TES HEADERS, HYPERTECH THERMOMASTER CHIP, 160* THERMOSTAT.
Old Feb 22, 2001 | 12:39 PM
UnderDogRS's Avatar
i run low 15's. mods in sig. and that was with a lot of sliping and a slow shifting tranny.
hth.
RS
1992 Camaro RS
Mods:
Custom chip, 14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge,A/F guage, 3-Row Al rad. , 180* t-stat,Proform 1.5 roller rockers, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods, !Cat
Next
454 TB,Victor Vortec intake,Vac FPR,LT1 cam,Roller timing set,"glass" hood
65# inj,new chip
Best Time: 15.279@89.02MPH
Underdog Racing
Old Feb 22, 2001 | 02:06 PM
big tex's Avatar
i ran a 15.2 with the mods on my sig...it was a great day for racing.
1992 305 TBI RS
Flowmaster cat-back exhaust, 14X2.5 open air element...and a T-5 on the way!
Old Feb 22, 2001 | 03:52 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I have said this a million times but these engines are just to unpretictable. I have heard of stock times as good as high 15's to low 17's! Might have to do with how well the person takes care of the car and if the car is fully tuned.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Feb 22, 2001 | 05:32 PM
89BlwnRs's Avatar
I for one don't think it has so much to do with the engines, but where the track is located, and most importantly the experience of the person driving the car. Tires and suspension also heavily impact drag times. Just simply saying it's an L03 doesn't accomplish much, but mine was dynoed at 158 RWP with my mods mentioned above and I have a best of 15.7.
Jason
Old Feb 22, 2001 | 11:12 PM
Basett Racing's Avatar
Mine went 15.68 stock ,minus air cleaner, 50# air in the front tires w/ 4* advanced timing. It now runs 14.91 with mods below and uncapped exhaust w/ a 70/30 mix of 93 octane and 105 octane.
A friend's 89 Formula went 15.98 stock, so I guess it just depends on the car.
Underdog RS, I was running 15.32 when I had all the mods below except 'Vette servo and 3.42's. When you get gears and Vette servo/shift kit, you ought to be in 14.70-14.80's easy. 15.28 is pretty quick for 2.73's. These cars have 9.5:1 compression and they like about 6* adv timing and a little higher than 93 octane gas (don't try to run straight race gas 100-110, just blend some with your pump gas and put about 50# of pressure in your front tires and I think that car will surprise you. I would also get a cut-out put in before the cat, for use at the track, bacause I still have stock manifolds/y pipe and ny cut-out picked my up almost 2 tenths.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
R.I.P. Dale Earnhardt #3
[This message has been edited by Basett Racing (edited February 22, 2001).]
MustangBeater20
Oct 29, 2022 09:20 PM
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
