92 RS smells like gas.
Old Mar 19, 2001 | 06:33 AM
cbpldc's Avatar
Hey all,
I have a friend who's 92 RS smells like gas inside the car after driving it awhile. So we got under the hood and went to open the aircleaner. We had a very hard time getting the lid off, which is strange considering that this car is extremely clean and there isn't bunch of road gunk under the hood. When we popped it off of there (finally), there was gas on the under side of the lid. Is this normal? My 92 RS doesn't do that. Any possible causes/ remedies? My friend seems to think that it is an issue with the charcol canister, but I really don't know where to start. Any ideas?
TIA,
Chris
Old Mar 19, 2001 | 07:27 AM
88firebirdTBI's Avatar
My 305TBI firebird does the same thing. When i take of the lid there is gas on the top. Do you ahve an after market air cleaner? I have the open element K&N kit. it could be too much air i am Guessing? i don't really think it does much.
Steve
88 Firebird TBI - Open Element, Cat Delete K&N filter 14*4 element
1/4: 16.1@85.7
Old Mar 19, 2001 | 07:57 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
He might have leaky injectors too. take the air cleaner lid off and have someone get in the car and start it up and rev the engine. See what the injectors spray pattern does at idle and at high rpm's. Then come back and give us that info.
BTW: Get a towel and cover his coil and his dist. cap when u do this. If fuel is going to go everywhere, u don't want it near any possible spark.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
[This message has been edited by 91Bird305 (edited March 19, 2001).]
Old Mar 19, 2001 | 08:12 AM
cbpldc's Avatar
It's a bone stock air cleaner with a K&N filter. Leaky injectors huh? How is this remedied? My RS does it too, but not as bad as his? Would running some injector cleaner through it help any? Just a thought.
THanks,
Chris Payne
Old Mar 19, 2001 | 10:38 PM
Fordslayer's Avatar
This seems to be the problem with a lot of rs, my 91 rs does the same thing and i was told injectors is the problem so any info on how to fix would be excellent, thanks
91 RS, 305 TBI
-Jet Chip 2
-160 degree thermostat
-Spintech Exhaust
-Ram Air (custom)
- K&N airfilter
Future Mods:
-350 Ram Jet engine
-T56 tranny
-3.9.6 Possi Rearend.
Old Mar 20, 2001 | 11:22 AM
buy new injectors, also check fuel pressure
Steve
1/4: 16.1@85.7
Old Mar 20, 2001 | 03:40 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yeah, there really is no way to "fix" injectors. Once there broken, there broken. Check out Turbocity.com for new ones. They come flow matched too and u can send ur bad ones in for a core charge and get money back on the deal.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Mar 20, 2001 | 06:47 PM
BigChevy342's Avatar
I was told that you could take your injectors to gm and they would rebuild them..?
Old Mar 20, 2001 | 10:10 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
how do you take em to gm? drive to detroit and say, hey, will you rebuild my injectors?
im just not understanding.
Old Mar 20, 2001 | 11:39 PM
To your local ASE cerified gm dealership,
Old Mar 20, 2001 | 11:43 PM
cbpldc,
I I were you i would look in the yellow pages or goto a gm dealership first to see if they will rebuild them for you, cause those babys are what like 60 dollars each? And you also need to buy the tb pod gasket set, and the fuel screens... Just a idea, i think the rebuild is like 35 dolalrs with the fuel screens and gaskets
Twin_Turbo
Mar 14, 2016 10:10 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
Glowsock
Sep 11, 2015 11:09 PM
